Which hans
Old 08-02-2009, 04:15 PM
jackcasual
jackcasual's Avatar
Default Which hans
Tryin to decide the heavier Sport model or the lighter Porfessional model?
Old 08-02-2009, 04:47 PM
CHJ In Virginia
CHJ In Virginia's Avatar
I have the sport model. I think that the premium in $ to get the lighter Pro model is very high to save a few ounces in weight. You will never notice the difference when you are wearing the restraint. Be sure to get the sliding tethers, definitely needed for side to side vision - well worth the $
Old 08-02-2009, 07:08 PM
Lan.Jet
Lan.Jet's Avatar
Old 08-02-2009, 08:40 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
sport umless your in F-1
Old 08-02-2009, 09:17 PM
geerookie
geerookie's Avatar
Also have the sport with sliding tethers and love it! You will never feel the difference in weight when you are in the seat.
Old 08-03-2009, 09:51 AM
cgh1
cgh1's Avatar
I have the Pro model because I got a good deal on it.
Because of the way the system is implemented, the only time you'll notice the weight difference is when the system is not in use. Usually at that point, you can take it off...
Unless you're getting a 'deal', save your $ and go with the Sport model.
Just make sure you're getting the correct rake angle (Model 20 or 30) for your seating position requirements.
Old 08-03-2009, 11:28 AM
jackcasual
jackcasual's Avatar
Thanks,appreciate the input.
Jeff
To Which hans
Quick Reply: Which hans
