track wheels question???
Old 08-02-2009, 09:24 PM
bearnest
bearnest's Avatar
Default track wheels question???
I have a 06 coupe, has anyone bought any c5 wagon wheels and used
them for hpde?? wheels are 18x9.5 Could I run these on the front or the rear? Was thinking on sending them to weldcraft to get widen.
Old 08-02-2009, 10:49 PM
froggy47
froggy47's Avatar
I Picked up some ww to use the rears on the front of my c5z for some odd size yoko slicks I picked up.
Worked fine, I know not your specific application but they are strong enough.
I don't know why you would have anyone widen a wheel.
Isn't that trusting an awful lot to the shop that does the work on a wheel that you will trust to over 100 mph?
OEM & aftermarket (race wheels) are tested to stand up to the stresses.
Shops that widen???
2 cents.
Old 08-02-2009, 11:40 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
they work fine, but I'd just buy C5Z06 rears if you want something wider.
Old 08-03-2009, 01:10 AM
Todd Z
Todd Z's Avatar
Get C5 18" x 10.5" on all four corners. Easy to get tires and will clear a BBK if you get one.
Old 08-03-2009, 01:56 AM
RaleighSS
RaleighSS's Avatar
If you run 18" x 10.5" on all 4 what tire size combo would you run ????
Old 08-03-2009, 03:12 AM
Z06Fix
Z06Fix's Avatar
315/30's
Old 08-03-2009, 03:27 AM
RaleighSS
RaleighSS's Avatar
Originally Posted by Z06Fix
315/30's
on all 4 ?
Old 08-03-2009, 02:35 PM
bearnest
bearnest's Avatar
hey guys let me explain a little better. I plan on running 18x11 in rear 18x10
up front I found a deal on c5 wagon wheels 18x9.5 thought I would have them
widen for the back. My question is the offset on a c5 the same as c6. what size
came on c5z what size came on c5. thanks ps what is bbk big brake kit??
new to this if you cant tell. these wheels will be for track only r coumpond tires
To track wheels question???
Quick Reply: track wheels question???
