Effects of unequal caster?
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I recently put a C4 suspension under my '69, and I'm doing some alignment tweaks on it. I can measure the camber and toe-in, but presently I don't have a caster gauge yet. So, the caster is just roughed in. What is the steering effect if the l/r caster isn't the same (ie: pull to either side)?
Thanks,
Mike
Thanks,
Mike
Thanks a bunch!
more castor also increases steering resistance, and gives you more camber while turning. Excessive unequal castor will give an uneven steering resistance turning different directions, not give adequate self-centering, and cause handling to vary (give symmetric static camber) from direction to direction.
If you go to my site and download my alignment guide (davidfarmerstuff.com), you can easily measure castor at home. Castor doesn't have to be perfect, but you want it with 1/2 degree or so.
