Pad taper report (DRM AP brake packge)
Former Vendor
Well after I finally finished off my front pads, I wanted to check pad taper. Here is what I came up with (not bad for a 10 year old brake system)
3.680 inches
3.674 inches
3.658 inches on the "inside" of the pads
3.641 inches on the "outside" of the pads
This was just a quick measurment to see if anything stuck out. Everything seems pretty good if you ask me. Somebuddy will ask, why the centers are smaller numbers, well I would guess I was pushing in pretty hard on the caliper-pads to get a picture and to make sure all the pads didn't fall over.
Just checking things out and reporting my findings.
Randy
www.dougrippie.com
3.680 inches
3.674 inches
Randy
www.dougrippie.com
Former Vendor
I know what you are saying. There is some life left in them. One of two things is going to happen after my next track event. 1. The car will be raced by one of my customers. 2. me at Comp school followed by 2 days of racing in the spring. Either way, I really didn't want to be a day or two away from backing plate vs rotor. So I swapped them out. They are about 75-85 percent gone compared to a new pad.
Randy
Randy
Flink, i agree with you. If those were from my stoptech setup that would be 50% useful life left. Heck, i just checked pads this weekend and they had about 3/16" left and i said good to go for a two day event coming up. Obviously i will watch them but that's still a lot of material left considering what you start off with.
Former Vendor
Former Vendor
We replace torque tube rubbers every other weekend, oil every weekend, tranny and diff every other weekend, brake and clutch everyday, I even have leaked down this stock bottom end after everyday at the track. I learned car prep growing up around the shop when we were pro racing. Keep working on it, even if it's not broken.
Randy
Former Vendor
Damn you guys are hard on a guy. Just thinking ahead is all.
The next event is our local Corvette club track rental. I gave them all something to talk about last time I ran with them. This time I would like a perfect running car all day. Check the oil, add gas and have fun is the idea.
Next spring at comp school, "Sorry I can't run hard, I have to beed in brakes" Not a good way to start a weekend.
Or if the car switches hands, two track days later "The pads are shot, when can you get me in"
Randy
PS I'm the cheapest guy on this forum, everything I do has a reason. Which is to either go faster, or save money down the line.
Randy
50% pad thickness remaining does not mean 50% pad life left. closer to 20% pad life remaining.
Changing pads at 50% is a good safety precaution, then take the pads with with you to events. as spares or for the guys who need brake pads as they wore theirs down to the backing plates
Well again if you are rich and that makes you comfortable then go for it. I disagree that 50% = 20%, not sure where you would come up with that one. I just got through running this weekend on what you would call slivers but they held up just fine and i ran "extremely hard". I swapped out pads that were down to 1/16" with one twice as thick 1/8" and they ran fine all weekend.
Just curious, why would you want to take that kind of chance? Seems to me that new brake pads are cheap compared to damage repairs or worse.
Maybe i'm just have the best luck with my pad and brake choice. I run carbotech XP10/8 combo and they have worked great. Carbotech told me they were good right up to the backing plate and it's no lie.
Why would i take a chance...i'm not chancing anything if i'm watching my wear. I guess you've never corded a tire or broken a rotor either.
Former Vendor
I will run the hawks again once I get some matching rears. They seem to stop, but the abs didn't like the difference.
Randy
