Koni expert needed - technical
Old 08-17-2009, 09:32 PM
froggy47
froggy47's Avatar
Default Koni expert needed - technical
Got some used 8240 1115 Sport (yellows) and I need to chase the threads on the pin top - these are rears.
Anyone know the die size? None of mine (metric or sae) seem right.
Thanks.
Not for Vette.
Old 08-19-2009, 12:16 PM
dcvee
dcvee's Avatar
Thanks.
Not for Vette.
Any good machine shop in your area should be able to measure those threads. Should be 10x1.25mm I believe. Hey, I used to run those on the rear of my M3's???
Don
Old 08-19-2009, 07:04 PM
froggy47
froggy47's Avatar
Don
You win, 10x1.25
To Koni expert needed - technical
Quick Reply: Koni expert needed - technical
