Test and tune results - Pfadt SS front bar and inverted shocks
Old 08-23-2009, 11:40 PM
CorvetteZ51Racer
CorvetteZ51Racer's Avatar
Default Test and tune results - Pfadt SS front bar and inverted shocks
Just wanted to send out a quick to the guys over at Pfadt. Yesterday I installed a slightly used C6Z SS Front bar and a brand new set of inverted shocks. I went out to a test and tune autocross today, starting with everything set as close to the stock setup as possible. I put in roughly 35 runs today, playing with alignment, pressures, shocks and bar.
Going into today, I had issues with corner entry understeer and mid-corner wash-out. Corner exit was ok and power down was decent, though snap oversteer was a constant concern.
Using pyrometer and tire wear data, I settled on an alignment that was essentially the same as I had been previously running. We then attacked the bar and shocks. After several different setting changes, I found the right setup for me (VERY different from the stock stuff), and all I can say is WOW! Turn-in response is almost instantaneous, while the rear end stays planted. Mid-corner wash-out is gone, and power-down on corner exit is more confident and break-away is more progressive with throttle-on oversteer more controllable.
For just shocks and front bar tuning, it transformed the car! As you can imagine, with 35 runs, I got pretty consistent with the course, and I was consistently running 1.5-2 seconds faster on a 55 second course, and more importantly it was EASIER to drive the car fast and consistent. A big to those guys with the shocks and that bar. Excellent craftsmanship, adjustability and matched well to the other stock suspension pieces required by SCCA SS class rules!
Old 08-24-2009, 10:59 AM
Datawiz
Support Corvetteforum!
Datawiz's Avatar
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
I'm extremely pleased with the same setup.
Old 08-24-2009, 01:33 PM
David Borden
David Borden's Avatar
Great report! Where did you settle on the shock adjustments front and rear? Was it near the middle of the adjustments or at either end?
Old 08-24-2009, 02:51 PM
0Corvettes of Dallas - Parts
Former Vendor
Corvettes of Dallas - Parts's Avatar
Go Pfadt!
-Adam
Old 08-24-2009, 06:57 PM
CorvetteZ51Racer
For my driving style, I liked the rears at 6 and the fronts at 12 (for consistency) and 16 for max turn in (unforgiving though...if I over drove or over-braked in a corner, the run was wasted). For my driving style, I had to stiffen the front of the car a LOT. Softening the rear up gave me more progressive and more controllable break-away on corner exit.
Your results may vary
Old 08-25-2009, 10:37 AM
aggie_corvette
aggie_corvette's Avatar
Fun day on sunday, it was really hot and i was exhausted by the time i got home.
Old 08-25-2009, 11:26 AM
Pylons
Pylons's Avatar
I have the Addco 35mm hollow bar and the Pfadt shocks on my Z51. 10 front and 6 rear seems to be where I'm happiest...if anything, I might soften the rear a bit more.
stiffer front bar is a must on the Z51 for autox, imo...I tried stock, 32mm hollow, 35mm hollow, and 35mm solid
Old 08-25-2009, 10:41 PM
CorvetteZ51Racer
What? HOT? You think drinking 2 gallons of water each and STILL be dehydrated was HOT? I definitely owe you a few for your help! Just let me know when you want some motor/powertrain work
Old 08-26-2009, 05:24 PM
Aaron Pfadt
Aaron Pfadt's Avatar
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
-Aaron
To Test and tune results - Pfadt SS front bar and inverted shocks
Quick Reply: Test and tune results - Pfadt SS front bar and inverted shocks
