2007 Jayco Seneca HD 36FS...Duramax diesel with Allison tranny (it's a Kodiak 5500 chassis)...somewhere between 36 and 37 feet long. Can technically sleep 9: 2 in the overcab, 2 in the queen bedroom, 2 in bunk beds, 2 on a pull out sofa, and 1 on a converted booth dinette (that one better be short!)...9 people would not be very happy in there for very long though!
depends how you want to measure towing capacity. it has an 8 or 10k lb hitch, but I'm pretty sure towing that much would put it over it's GVWR (26k lbs). I haven't been on a scale, but with fuel and water tanks fairly fuel, I bet I'm close to 26k with the open aluminum trailer and vette (which is probably about 4500 lbs).
... depends how you want to measure towing capacity. it has an 8 or 10k lb hitch, but I'm pretty sure towing that much would put it over it's GVWR (26k lbs). I haven't been on a scale, but with fuel and water tanks fairly fuel, I bet I'm close to 26k with the open aluminum trailer and vette (which is probably about 4500 lbs).
Daym ... well, I don't think you're gonna have to worry about "the tail wagging the dog" with that setup!
Very nice i'm glad we got out diesel pusher a rig like yours woulda been better for me living on gravel but the diesel pusher has been working great 29k total capacity and i sit at around 26k with half water. full propane. and all the gear, spare wheels, and tires and such. so your propbly not to far off on your estimate on your weight mines a 34ft diesel pusher with the cummins.
