New Z06 Trans & Diff. Any break in needed?
Old 08-25-2009, 08:06 PM
mountainbiker2
mountainbiker2's Avatar
Default New Z06 Trans & Diff. Any break in needed?
I just had installed a new C5 Z06 transmission and differential. I might be able to put on 250 miles before my next autocross. The engine is a stock Z06 motor with headers. The autocross has 9 practice laps then 3 race laps that count. I went just a couple of hundred miles on the motor before I started racing it. It runs great. Can I do that safely with the trans and diff? I really don't want to break anything for awhile.
thanks,
Steve
Old 08-25-2009, 09:37 PM
froggy47
froggy47's Avatar
thanks,
Steve
Hi Steve,
Don't know, but here's a bump for you. What fluids did you put in?
Old 08-25-2009, 10:39 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I think you'll be fine, drive it some if you can, but gears don't wear like bearing/ring surfaces do.
Old 08-26-2009, 07:59 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
I (actualy Mark) put 16 miles on mine before doing TT at Rd Atl. Guess I should change that fluid soon.
Old 08-26-2009, 03:03 PM
wtknght1
wtknght1's Avatar
Yep, Dave's right...you'll be fine. I never had to swap a tranny with my C5, but I did put a diff in there. I put about 300 miles on it before really pounding on it hard. I had no issues. The whole C5 driveline is pretty bullet-proof and you can pound on it immediately if you need without any real worry. Drive hard!
Old 08-26-2009, 04:37 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
me I put two brand new diffs in my car and they both were bad in 300-400 miles with breakin baby driving on the street what luck huh?
To New Z06 Trans & Diff. Any break in needed?
Quick Reply: New Z06 Trans & Diff. Any break in needed?
