c5 & c6 control arm differences
Old 08-26-2009, 11:46 AM
exracer28
exracer28's Avatar
Default c5 & c6 control arm differences
Is there a difference in the arms? Some say yes because part number change and others have told the change is so minor not to worry about.
Anyone know for sure?
Old 08-26-2009, 11:49 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
It depends on which one. The upper rears on a C6Z are considerably different.
Old 08-26-2009, 02:19 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
the fronts should be the same, or very similar. The rear uppers are different to compensate for the longer wheelbase, but I think the rear lowers should be the same-ish, as the wheelbase change was made in the subframe.
Old 08-26-2009, 02:20 PM
exracer28
exracer28's Avatar
Just wanted to know which ones fit. Sounds like upper rear C6Z is stand alone.
Does that imply others might/do interchange?
Old 08-26-2009, 03:32 PM
ghoffman
ghoffman's Avatar
Well, I did a comparison of the rear upper C6 and C6Z and it appears that the only difference is the way it mounts and the associated bushings. The C6Z has the "dogbones" like the C5 and C6 front uppers.
To c5 & c6 control arm differences
Quick Reply: c5 & c6 control arm differences
