Help with control arm bushing.
Old 08-31-2009, 11:05 AM
blkc6z51
blkc6z51's Avatar
Default Help with control arm bushing.
My upper control arm bushing is coming out, has this happen to any
one before. And how hard is it to press back in. If I take the
control arm off can a shop just press it back in for me.Thanks for any help.
Old 08-31-2009, 12:20 PM
longdaddy
longdaddy's Avatar
"normal" track wear. you cannot press it back in as it is bonded to a control arm. once it is pushed out to the point where you cannot see it on one side at all, you need to either switch to polyurethane bushings or get a new control arm
Z/28 (03-05-2024)
Old 08-31-2009, 12:46 PM
argonaut
argonaut's Avatar
Take a look at these recent threads:
http://forums.corvetteforum.com/auto...te-to-all.html
http://forums.corvetteforum.com/auto...s-options.html
http://forums.corvetteforum.com/auto...hing-swap.html
Old 08-31-2009, 06:59 PM
blkc6z51
blkc6z51's Avatar
Thank you that will help a lot.
To Help with control arm bushing.
Quick Reply: Help with control arm bushing.
