Front lower control arm replacement
Old 09-03-2009, 04:51 PM
Rob Burgoon
Rob Burgoon's Avatar
Default Front lower control arm replacement
I have a thread in C6 tech, but not getting much love over there.
I am sure some of you guys have done this a few (dozen) times. Would you mind replying to my C6 tech thread?
http://forums.corvetteforum.com/c6-t...placement.html
Thanks!
Old 09-03-2009, 06:49 PM
2K3Z06
2K3Z06's Avatar
Location: KADS- If it has wings or an engine, I can break it. Dallas TX
Piece of cake. 3 bolts and loosen the lower shock mounts. Use a breaker bar and 1/2 inch drive sockets, because they are on there tight. Use a allen wrench to hold the ball joint in place while you tighten the nut.
Use a floor jack to hold the leaf spring up. Thats about all there is to it.
If you do the uppers, just be careful you don't crossthread the nut serts in the frame.
all the best.
Old 09-03-2009, 06:52 PM
ryan0
ryan0's Avatar
or overtorque
Old 09-03-2009, 09:36 PM
mgarfias
mgarfias's Avatar
Originally Posted by ryan0
or overtorque
Studs are your friend.
To Front lower control arm replacement
Quick Reply: Front lower control arm replacement
