Tire pressure DE/TT 710's
Old 09-08-2009, 07:21 PM
froggy47
froggy47's Avatar
Default Tire pressure DE/TT 710's
I'm used to being able to adjust between runs in autox, so this is a bit new doing 20 min of laps (1.6 mi course).
It's San Diego 9/24, probably cool am, maybe hot pm (air base on the bay).
c5z 295's & 315's.
What do you say?
For autox I usually run 29/25 or 30/26.
Old 09-08-2009, 07:36 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
I aimed for 28psi hot, so I'd start the first session around 22-24psi cold and adjust accordingly afterward. Just take the first few laps carefully, which you should do anyway on cold tires regardless of pressure.
Old 09-08-2009, 07:39 PM
froggy47
froggy47's Avatar
Wow, no kidding, that low (for the hot pressure). I am glad I asked. I usually gain 3 to 4 psi for an autox event & bleed off. Maybe I should do 5 laps & pit for a quick press ck/adjust & back out for the first session.
Thanks.
I was thinking of comp mode for about 1/2 the first session, then off the rest of the day.
Old 09-09-2009, 11:34 AM
froggy47
froggy47's Avatar
Old 09-09-2009, 08:24 PM
froggy47
froggy47's Avatar
Old 09-09-2009, 10:19 PM
sperkins
sperkins's Avatar
Ahhh... More track record setting secrets revealed.
I could never get mine that low with my factory camber settings. The lowest I ever attempted was 28 cold. The tires rolled over so bad that it actually wore off the treadwear, traction and temperature ratings off the side of my Hoosiers.
Old 09-09-2009, 10:51 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
that's actually a good way to sneak some non DOT hoosier slicks into TT. put a heat cycle on them with +2 of camber, run 'em through tech as A6s/R6's.
man I've been hanging around Toby too much....
Old 09-10-2009, 07:15 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
That was for Kumhos, not Ho-Ho's. See Mark's 20pg thread for Hoosier pressures. And watch your head explode.
Old 09-10-2009, 01:17 PM
froggy47
froggy47's Avatar
I've got about 2.5/1.5 neg so should be ok on the rolling over part.
Old 09-17-2009, 11:45 AM
froggy47
froggy47's Avatar
Anyone else. Not looking for track record pressures, just safe/fast/decent wear pressures.
Old 09-19-2009, 04:38 PM
froggy47
froggy47's Avatar
To Tire pressure DE/TT 710's
Quick Reply: Tire pressure DE/TT 710's
