new to track events, do you run with windows closed or open?
Hi all,
so far I did two track events with my C5Z06. I ran the car with the windows down, but when you are hitting 120mph+ on the straights, there is a lot of wind comming inside the car. WHen I ran with the windows closed, I felt more "comfortable". Then again, it gets hot in there.
Is one supposed to run the ventilation system on (AC off) with heat on full blast and windows open, or can i run with the windows closed, and ventilation full blast set to the "coldest" temperature w/o AC?
thanks
thanks
Windows must be fully open. Even in the rain. If the worst happens and you are unable to move, the safety workers don't want to have to start breaking glass to get you out of the car.
St. Jude Donor '09
I don't think you car race with the windows up. A friend of mine races his Z06 with the A/C on and his windows down. It gets a bit warm here in SoCal. It was warm in Hawaii when I tracked my car there but I never used the A/C.
San
San
windows down. less glass to fly around in case of incident, easier to get to the driver.
AC will not do you much good, but if you point the outlets at your neck area it will help a little.
All events I've been to require that the windows are open.
All, that is, except for the Daytona HPDE run by Audi last Dec.
In 2007 we had to have the windows open for the event.
However in Dec 2008 you could run with them open or closed - your choice. We were told the rescue personnel said they wouldn't have any problem getting into a car with the windows closed.
I ran with the windows closed and it was very nice when running in excess of 150 mph.
BTW, instead of sticking an arm out the window at 140 and driving around the bumpy banking with one hand on the wheel and the other sticking over top the car to signal a point-by, we used the turn signal to authorize a pass, so you didn't need the window open.
I think you can see the window is closed in the picture below.
Butt.....that's the only event I know of that approves closed windows.
Come to the event this Dec 4-5-6 and you'll probably be able to drive with the windows closed!
Bob
Bob
I get the windows down thing but at that point what are the risks of running without arm restraints... ?
(Assuming not everyone has Gary's trick window netting. http://hardbarusa.com/hardbar/produc...products_id=87 )
Almost everyone has a "Windows Down" rule. It was a little amusing when Preston Henn and his Bugatti were told they couldn't run at Sebring. He was black flagged because on the Bugatti the windows automatically go up a set mph. Not even the Bugatti engineer could over ride the computer system. Preston being the gentleman he is just took his new Bugatti home.
Richard Newton
Richard Newton
Think it is really only the vipers that need to run with the heat on full to help cool then engine.
Only times used the ac was sitting in the hot pits waiting to go out. once we rolled the ac was turned off and windows down.
A favorite comment at the drivers meeting "You must run with both windows down so the rescue workers can drag your lifeless body from the car"
Speaking of this (and since the question was answered well) is there any way to reduce the drag by having the windows down?
I think that openings aren't allowed for race cars into the cabin? Because of fire issues? What about for HPDE cars?
Former Vendor
I would much prefer them closed, less crap coming in from cars around you if they get off course or worse if you do in a bad way, even just the dirt it is mess to clean up later
I have been hit in the side of the head by rubber chunks from a car in front not even off the track and it has hurt a couple of times, better to let the window take the blow in my opinion
( I have also ran some 30 minute sessions in 100+ degree heat with my heater on full blast to keep the engine alive, different car though)
Most local clubs require windows down. Their claim is that corner workers won't have trouble getting you out if they are down. I have seen a few crashes in 20 years,and the side windows are first to blow out in a crash.
The actual incident that precipitated this rule (as well as long sleeves) for Midwestern Council of Sports Car Clubs happened in mid 1990's.
A friend driving his RX-7 twin turbo went off, after the right front rotor shed a pie shaped chunk in the braking zone at the end of a long straight at Blackhawk. The wheel locked and then removed itself leaving the 3 wheeled car off track sideways at 100 MPH plus or minus. Somehow the car ended up getting airborne while traveling backwards and landed hard tail first. The first impact may have been on one of the front corners as he hit an abandoned concrete corner worker bunker and displaced it.
He had the windows up for better aero and was wearing a tee shirt at the time. Somehow the air bag deployed shortly after the side glass came into the interior, and my friend got glass blasted into his face and arms by the explosive force of the air bag going off.
He severed an artery in his arm, which the EMT corner worker got stopped in short order. His face looked like he took a shotgun blast as he was wearing an open face helmet. After a few weeks his body rejected all of the embedded glass particles and he recovered nicely.
1. I run windows down unless it is raining. If it rains, I park it. Why get the interior full of wet brake dust and take a chance on wrecking the car for a cheap trophy.
2. I do run windows up at Road America as it does reduce drag. (don't ask don't tell) For speeds up to 100, I don't think it matters, so i comply with club requests.
3. I wear long sleeves, because it is the rules. I don't believe that a thin long sleeve shirt would have changed the outcome for my friend. A Kevlar shirt or multi-layer suit... maybe.
4. A full face helmet with a visor down would have saved him a lot of grief. I run visor down to prevent crap from getting into my contacts.
Strange as it sounds, Spring Mountain lets students drive windows up all three days, and only requires helmets on the open lapping day, and maybe a few other times.
It makes it more comfortable with the A/C on, and you can hear the two way radio better, but I have wondered about the safety issue.
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Plus in a spin with the windows open, lots of dirt and grass in the car!! (luckily I have no first hand experience with that, yet...)
I'm getting the urge to take a run down and try Daytona some time, that's got to be added to the bucket list!
-Dan
If you keep your hands on the wheel and hit a wall you can break your wrist, thumbs, or arms. Ever see when pros know they are going to hit the let go of the wheel. You should also try to drve thumbs out of the wheel.
ALMS cars like Lou's have to run with the windows up because they're required to have a/c. Interesting.
Richard
Richard
Windows down were required at VIR since we did point bys. My instructor had me run the AC full blast the entire run. The compressor automatically shuts off at high RPMS anyway. When it is over 90 degrees in the car, the AC really helped even with the windows down.
