Need advice - emergency "tow hook"
Old 09-10-2009, 10:40 AM
psft_alum
psft_alum's Avatar
Default Need advice - emergency "tow hook"
I won't have time to install my front and rear tow hooks prior to my visit to the track tomorrow. What can I use as a last resort if I go off the track and have to pulled out a gravel trap, etc.? Would the rear sway bar work? what else?
Old 09-10-2009, 10:44 AM
wallyman424
wallyman424's Avatar
they can run the tow strap around the rear subframe. Definitely do not use the rear swaybar.
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Wrap it around any control arm.
Don't go off.
Randy
Old 09-10-2009, 11:06 AM
psft_alum
psft_alum's Avatar
Randy
Near the hub, I assume?
Thanks!
Old 09-10-2009, 11:17 AM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
like this guy
http://www.youtube.com/watch?v=u_ZY92mHzK8
Old 09-10-2009, 11:43 AM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
Anyone ever try a "T" or "J" tie-down hook on the end of the strap, hooked into the side rail tie-down slot (F or R as appropriate) and run under the car to F or R?)
Old 09-10-2009, 12:13 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Originally Posted by drivinhard
OMG, that's right up with with the helmet tear off going into the turbo.
Old 09-10-2009, 12:43 PM
davidfarmer
davidfarmer's Avatar
if you are in the gravel, they won't be able to access the frame hooks. If you go into gravel/sand without a toe hook, you will most certainly have a damaged bumper by the time they get through with you (if you are lucky)
Old 09-10-2009, 02:46 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Thanks!
You will be under the gun if you are stuck in the pee gravel. Just wrap it around anywhere around the control arm. Up by the subframe will be better. Don't worry about it too much until it happens, because hopefully you will not be in the crap.
Randy
Old 09-10-2009, 03:02 PM
BrianCunningham
Guys,
Could we not have novices installing straps near rotating parts?
Old 09-11-2009, 06:44 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
not sure I would want it around my control arm my GS was towed once and the bend the control arm.
Old 09-11-2009, 08:28 AM
beerkat
beerkat's Avatar
The best solution is to just stay on track, now if I would just learn to do that myself....
Old 09-11-2009, 10:44 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Depends on how stuck I guess. The control arm is much stronger then a rear tow hook held in by two 6mm exhaust hanger bolts.
Randy
To Need advice - emergency "tow hook"
Quick Reply: Need advice - emergency "tow hook"
