Tuning out second o2 sensors?
Old 09-25-2009, 11:13 PM
fatbillybob
fatbillybob's Avatar
Default Tuning out second o2 sensors?
Guys,
I might not get time to have my second 02 sensors turned off before my next trackday and get tuned after my exhaust mods. I suspect the MIL's for downstream o2 sensors will turn the MIL on. Will that doing anything to my engine performance or just turn on the MIL?
Thanks!
Old 09-26-2009, 07:56 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I think it just sets a code, I don't believe they are used for actual engine management.
Old 09-26-2009, 08:17 AM
Rob's 73
Rob's 73's Avatar
They are just there to verify that the CATS are working. Ignore the following codes if they show up.
P0137
P0138
P0140
P0141
P0157
P0158
P0160
P0161
Old 09-26-2009, 12:56 PM
exracer28
exracer28's Avatar
Originally Posted by fatbillybob
Guys,
Thanks!
The 2nd set checks that the cats are working. Remove the 2nd sensors, plug the hole, and secure the removed sensors.
Old 09-28-2009, 10:28 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Will they still throw a CEL?
Old 09-28-2009, 10:32 AM
drivinhard
drivinhard's Avatar
it will trigger the MIL, no performance effect
you can turn them off easy in HPTuners.
Old 09-28-2009, 11:07 AM
exracer28
exracer28's Avatar
They will not throw a code if removed from exhaust flow but still connected to the harness. Basic evaluation made by ECM is 2nd set air cleaner then set 1.
Old 09-28-2009, 12:38 PM
Rob's 73
Rob's 73's Avatar
If you leave them connected be careful on how you secure them. They get very hot.
Old 09-28-2009, 05:53 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Be one less thing to f with when dropping the exhaust.
Old 09-28-2009, 09:51 PM
exracer28
exracer28's Avatar
On my cars I use radiator hose clamps and clamp to the exhaust. Benn on the car for years but I do check each time I change oil.
To Tuning out second o2 sensors?
Quick Reply: Tuning out second o2 sensors?
