Brake ducts? Inside grill??
I'm looking for the tread that the forum member put front brake ducts on each side, behind the grill??????? I've done a search and can't find it. Anyone remember??? JD
http://forums.corvetteforum.com/c6-z...evel-pics.html
BTW, PCA is running an event here at Daytona Oct 9-11. I'd like to see another DSOM here!!!
Butt.....with your Katech beast you might need that brake cooling mod. I bet you'd be doing almost 200 across the s/f line and into the braking zone for T1 into the infield. 200 down to about 60 for the turn - that'll generate some heat!!!
Bob
Thanks Bob, I should have just called you first!!!!!!! Sorry I will be at Sebring that weekend with Chin. Have a great time and be safe, will talk to you after the Oct. weekend. Thanks again, JD
