Aftermarket steering wheels
Old 10-03-2009, 05:18 PM
OKsweetrides
OKsweetrides's Avatar
Sorry for delay flycastinguy....
ATI kit with Carbon fiber backing plate quick release.
I forgot which actual wheel I have, but it's got little thumb-juts to help keep a solid grip on it. I've never once had a problem with it slipping.
The C5 has the old school GM style splines, the C6's are different.
Old 10-03-2009, 06:03 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Originally Posted by HeyFred
Do they have a new site?
This one does not work.
http://www.accuratetechnologies.com/...aspx?tabid=118
Old 10-03-2009, 06:07 PM
Joe_Knesek
Joe_Knesek's Avatar
Originally Posted by John Shiels
I couldn't find anything directly but I did find this.
http://www.flamingriver.com/index.cf...rod/prd162.htm
Old 10-03-2009, 09:17 PM
John Shiels
http://performance.accuratetechnologies.com/
just signed on the forum and their banner popped up did not know they were worldwide.
Old 10-04-2009, 12:53 PM
John Shiels
Originally Posted by MySR71
I was in their shop about a month ago so I think they are still around. If you want to contact them, my suggestion is to call Mike Akerly at 248-848-9200.
I left a message thanks! I'll post what happens.
Old 10-04-2009, 05:55 PM
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
Old 10-04-2009, 09:41 PM
GettReal
GettReal's Avatar
I'd like the carbon cover and plug n play as well... When you talk to him, suggest a GP
Old 10-04-2009, 09:47 PM
flycastinguy
flycastinguy's Avatar
Seems like there's some business here for someone. Lets see if there's a response.
Old 10-04-2009, 09:56 PM
Joe_Knesek
Joe_Knesek's Avatar
If you are just interested in the carbon fiber plate you can get flat panels from DragonPlate.
http://dragonplate.com/
Old 10-04-2009, 10:12 PM
02impactblue
02impactblue's Avatar
I'm in for a complete kit as well!
Old 10-04-2009, 10:56 PM
fatbillybob
fatbillybob's Avatar
Here is my removable wheel solution for about $150 bucks summit racing catalog using these grant parts and a momo wheel for another $150 bucks
Cool thing is that it is easy to make an aluminum spacer to change the hub height too if you want to.
Old 10-05-2009, 11:34 AM
GettReal
GettReal's Avatar
Only those 2 parts needed and they bolt right on?? got a pic of your steering wheel column without the wheel on it? Just curious how it all bolts and latches together, I've never had my wheel off.
Steve
Old 10-05-2009, 12:03 PM
  #33
The Spark
The Spark's Avatar
what wheel are you using fatbillybob?
Old 10-05-2009, 12:28 PM
  #34
MySR71
MySR71's Avatar
How much slop is there in these splined couplers and do they wear and become sloppy over time? I've been doing a little reading about TEKNIQ AutoSport's removable steering wheel adapter for race cars (http://www.tekniqauto.com/US/snapoff/snapoff.htm) which uses two tapered pins rather splines to couple of the steering wheel to the steering shaft. One downside is that it takes two hands to removing the steering wheel.
Old 10-05-2009, 01:00 PM
  #35
flycastinguy
This looks very interesting. I don't have enough experience to comment on the pin vs. spline question. But from what I read the use of their hub adapter allows you to maintain distance of wheel from driver. Seems like this can be a good thing if your race seat is already properly distanced from pedals and wheel.
Old 10-05-2009, 05:19 PM
  #36
MySR71
MySR71's Avatar
I dont think I'm convinced that those pins are a stronger option then the splines.. seems like you could bend or snap those with a medium amount of force. (however, I'm not an engineer and Im sure they are totally safe) I'd like to see the rear of the backplate that attaches to the spline.
I don't think the pins are meant to be stronger than splines. Instead, they ensure there is no play in the steering system, ie, turn the wheel half a degree before the steering column starts to move. Some splines may have this. I can see where if done right, tapered pins should ensure no play even as the system wears with use. There should be no backlash.
All this being said, I've never tried the pin-based system so I don't know how good it is. Also, I don't know if they make a hub adapter for our cars (although they say they can adapt to Momo hubs). It does look like they allow a horn although some rewiring is probably needed.
My real intent for bringing up this other product was really to ask if others have problems with slop/backlash in their removable steering couplers. Either new or after some use.
Old 10-05-2009, 05:21 PM
  #37
John Shiels
called today and left message for Mike at ATI keep you posted.
To Aftermarket steering wheels
Old 10-05-2009, 09:39 PM
  #38
fatbillybob
Momo Montecarlo IIRC. I come from rack and pinion cars and feel the vette is overassisted so I am also using a smaller diameter wheel. 90% of my wheel use is +/- 90 degrees.
Old 10-05-2009, 11:24 PM
  #39
trackboss
trackboss's Avatar
The grant quick release is one of the best one's I"ve used. Almost no play. That being said in my old race car I had a very loose quick release, but once on track it was completely un-noticable. The ATI 6 bolt to 3 bolt adapter is pretty long and sets the wheel in the stock location. I prefer it even closer so I added a spacer. Using any of the commonly available 3-6 adapters will more the wheel forward a couple inches.
Old 10-06-2009, 10:03 AM
  #40
OKsweetrides
I honestly can't detect any play at all in the splines; mine's a pretty dang tight fight actually.
Quick Reply: Aftermarket steering wheels
