Katech Performance Corvette Aero Package Wind Tunnel Testing DATA + PICS and VIDEO
Old 10-06-2009, 10:09 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Default Katech Performance Corvette Aero Package Wind Tunnel Testing DATA + PICS and VIDEO
Here is my full report that explains everything in detail:
http://www.katechengines.com/street_...a%20report.pdf
Video:
http://www.youtube.com/watch?v=3-2qBGwLlHg
Pictures:
Special thanks to PAINRACE for letting us use his car.
__________________
Contact:
(e) zach@katechengines.com
Old 10-06-2009, 10:18 AM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Very thanks for sharing
Old 10-06-2009, 11:20 AM
Short-Throw
Support Corvetteforum!
Short-Throw's Avatar
Jason,
Kudo's to supporting your products with real tested data and always being straightforward. While many love to add aero parts to their cars for looks (nothing wrong with that as I love the look of your spoiler even by itself), you have supplied the required info to those that are actually looking for the give/take of aero packages. Those that race in whatever form understand giving up a few tenths in 2-3 straight-a-ways equates to gaining seconds in the curves. This package certainly will do that.
I can't wait to see painrace's car next time at the track!
Mike
Old 10-06-2009, 01:23 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Jason-Any Aero upgrades, by Katech, for the C5?
Thanks!
joel
Old 10-06-2009, 01:51 PM
PushinTheLimit
PushinTheLimit's Avatar
Thanks!
joel
Yea... I too would like to see something like this for the C5. Especially if I end up run in ST2, a spoiler something like this would be something I would be interested in.
Old 10-06-2009, 02:03 PM
Katech_Zach
Thanks!
joel
We have no plans to develop anything for the C5 at this time.
Old 10-06-2009, 02:08 PM
davidfarmer
davidfarmer's Avatar
any chance of getting the raw data (lbs). Curious how much Lift you start with, and how it converts to downforce
Old 10-06-2009, 02:25 PM
Katech_Zach
We are not publishing the absolute numbers because they can be easily misinterpreted or manipulated by our competition. Small things on the car can vary which affect the numbers. We did a baseline test and provided the data expressed as a percent from that baseline. The graph at the end of the report represents those absolute numbers in a visual way, but without giving the actual numbers.
Old 10-06-2009, 03:48 PM
Pumba
Pumba's Avatar
Jason,
Great video and data !
Would you speculate how much front-end lift would be reduced if you had added your louvered hood to the package that had the front splitter with the underbody tray, the side skirts, and your rear spoiler?
Oh yes, what did the day at the A2 wind tunnel cost?
Old 10-06-2009, 03:58 PM
AU N EGL
AU N EGL's Avatar
http://www.a2wt.com/
$345 / hr for the first 2 hours,
$490 / hr thereafter (which is also our regular pricing for all repeat visits).
Reservations require a $500 (full day) or $250 (half day or less) DEPOSIT to lock in the time, with the balance paid at the start of the test.
From there web site:
"Aerodynamic Drag:
Aerodynamic drag is a force in the opposite direction of the vehicles forward movement. You need enough power and torque to overcome this force and move the air around the vehicle. At low speeds drag is not a major concern, but as the speed increases, the aerodynamic drag will increase with the square of the speed (speed2). This means, in order to double the speed you will increase the drag force by four times.
If your drag force is 70 lbs at 50 mph, then the force at 100mph is 280 lbs. At 200 mph the drag force would be 1120 lbs, and so on.
Just when you get over that fact, there is one more that will really get your attention. Horsepower is affected by the speed as well, but HP = Drag force x velocity. This means as the speed increases the Horsepower required is now the cube of the speed. Every time the speed doubles the HP required to overcome the drag forces is increased by 8 times!!
If it requires 15 HP to overcome the drag forces at 50 mph, then it would take 120 HP to overcome the drag force at 100 mph. To reach 200 mph you would need 960 HP. 300mph would require 2700HP!! This is why you can add 50, even 100HP to your engine and not see a big gain in top speed.
http://www.a2wt.com/Wind%20Tunnel%20Testing.htm
Very Cool info.
A day in the WT could be worth more quite a bit in performance.
Old 10-06-2009, 04:18 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
That real
Old 10-06-2009, 04:27 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Thanks for the response. But, that's a bummer.
Old 10-06-2009, 04:42 PM
Pumba
Pumba's Avatar
I agree !
The C5 is in serious need of a front fascia - front splitter combination that moves the air around the vehicle, instead of under it. We have too much front-end lift.
A front fasica - splitter similar to what was used on the C5R race cars would be a good starting point.
Those pieces and some time in the A2 wind tunnel, with a selection of rear spoilers would be very informative.
Old 10-06-2009, 04:45 PM
davidfarmer
ACP makes an awesome C5 setup, in fiberglass or carbon.
Old 10-06-2009, 04:52 PM
Pumba
Pumba's Avatar
A Google search did not turn up a company with ACP as its initials who manufactures C5 parts.
Help?
Old 10-06-2009, 05:03 PM
Katech_Zach
I agree !
There are plenty of companies who are already in the C5 aero part market. We will be focusing on the C6 and C7.
Old 10-06-2009, 05:04 PM
Katech_Zach
Help?
Advanced Composite Products
http://www.acproducts.us
To Katech Performance Corvette Aero Package Wind Tunnel Testing DATA + PICS and VIDEO
Old 10-06-2009, 08:05 PM
Bahnzii
Bahnzii's Avatar
Jason that looks great and thanks for the Video and Data!!
Any chance you will do one more test with the World Challenge Hood??
It looks like November if we want to order Config 4 ??
Old 10-06-2009, 08:07 PM
Katech_Zach
We don't have any immediate tesing planned but I would not rule that out.
Yes, it would be safe to say November for the undertray and brake ducts.
Old 10-08-2009, 12:13 PM
Swiftwater Z06
Swiftwater Z06's Avatar
Default Justifying cost of aero package?
I don't think your testing report mentions anything about car speed at which the aero package begins to produce a significant speed/control advantage. In trying to justify the cost of the package, can you make some comments, speculative or otherwise, about the speed range in which the two best aero packages are creating an observable speed/control enhancement?
Quick Reply: Katech Performance Corvette Aero Package Wind Tunnel Testing DATA + PICS and VIDEO
