C-5 Calipers is z06 the same as z51
Old 10-06-2009, 05:19 PM
jaybar
jaybar's Avatar
Default C-5 Calipers is z06 the same as z51
I have tired to search this question but could not get an answer. I have a 00 FRC and was offered some ZO6 calipers, but they looked the same as my z51's. I did not have them side by side so couldn't tell.
Whats the answer and if they are different are they that much better. I use z51 calipers with Carbotec Panther 12/10.
Thanks,
JayB
Old 10-06-2009, 05:57 PM
0Vector Vette
Former Vendor
Vector Vette's Avatar
same caliper....differant color.
Old 10-06-2009, 06:03 PM
geerookie
geerookie's Avatar
The only difference is the color.
Old 10-06-2009, 08:01 PM
jaybar
jaybar's Avatar
Thanks, that is what I thought.
Old 10-06-2009, 09:18 PM
0C5stein
Former Vendor
C5stein's Avatar
Thanks,
JayB
The C5 Z06 calipers (front and rear) are the same as a regular C5. And those are the same as a regular C6 (other than the script on the front).
However the C6 Z51 rear brake caliper has a smaller bore than the C5 and Base C6.
the 0731 & 0732 pad shape is correct for all of them.
Old 10-07-2009, 01:01 AM
Bimota Guy
Bimota Guy's Avatar
Not exactly. The regular C6 caliper is beefier across the bridge than the C5 version. Several T1 racers have reported they last longer than the C5 calipers. They take the same pad. I now have them on the front of my race car.
Old 10-07-2009, 02:02 AM
0C5stein
Former Vendor
C5stein's Avatar
Huh, I didn't notice. I'll have to check that out tomorrow at work. Good to know, Thanks!
Old 10-07-2009, 07:35 AM
jaybar
jaybar's Avatar
Interesting...but will they clear the 17 inch zo6 wheels?
Old 10-07-2009, 09:51 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
Yes they will, the C6 caliper still spreads just not as quickly.
Old 10-07-2009, 06:50 PM
0C5stein
Former Vendor
C5stein's Avatar
I just measured them and found that the C6 calipers ar 0.015" thicker in the web.
IMO - I wouldn't spend any money for the upgrade from C5 to C6 calipers, but if someone gave em to me I'd run em. Or if I had to replace some failed C5 units, I'd consider replacing them with C6 units.
Old 10-08-2009, 12:29 AM
Bimota Guy
Bimota Guy's Avatar
Exactly. Replace them w/C6 version when they need to be replaced.
To C-5 Calipers is z06 the same as z51
Quick Reply: C-5 Calipers is z06 the same as z51
