T1 Sways or Stay with Hotchkis?
Old 10-11-2009, 04:12 PM
Wicked C5
Wicked C5's Avatar
St. Jude Donor '04
Default T1 Sways or Stay with Hotchkis?
I just picked up a 2004 Z06 which has the stock suspension but the owner include some T1 Sway bars. My current car has Hotchkis bars and Pfadt coilovers and I am pretty happy with the setup but I do run Toyo RA1's and I am always looking for ways to impove handling.
My car isn't a dedicated track car but I don't mind if it rides a little rough. I plan to keep the Pfadt coilovers. Car will be about 60% street and 40% track. Let me know what you guts think?
Old 10-11-2009, 04:58 PM
sperkins
sperkins's Avatar
'04 Z shocks and T1 bars make for a really good combination (that's what I run). If you can deal with the noise from the links, I would definately put them on.
Old 10-11-2009, 08:03 PM
froggy47
froggy47's Avatar
T1 bars will tie the suspension together side/side so the car is almost like a kart. Great on a smooth track, sometimes not so great for street driving. Try it out, it's pretty easy to swap bars in/out.
Old 10-14-2009, 12:56 AM
Steve@RSD
Steve@RSD's Avatar
St. Jude Donor '13
I vote Pfadt Street Sway bars. Best all around bars on the planet!
That's not just what we sell, that is what I run.
Steve
Old 10-14-2009, 01:06 AM
Wicked C5
Wicked C5's Avatar
St. Jude Donor '04
Steve
Sure if you'll take trade ins for the T-1's!
Old 10-14-2009, 07:54 AM
Allthrottleandsomebottle
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Old 10-14-2009, 09:27 AM
PA Z06
PA Z06's Avatar
I totally agree. I have the same setup. If I did coilovers I migfht not keep the t1s
Old 10-14-2009, 09:36 AM
drivinhard
drivinhard's Avatar
run the stock links
my cross weights are almost perfect w/ such
Old 10-14-2009, 11:38 AM
sperkins
sperkins's Avatar
Originally Posted by drivinhard
run the stock links
Ha! Another speed secret revealed.
Old 10-14-2009, 11:40 AM
Wicked C5
Wicked C5's Avatar
St. Jude Donor '04
run the stock links
So you really think I should dump the adjustable links?
Old 10-14-2009, 11:46 AM
drivinhard
drivinhard's Avatar
The T1 bars are noisy even with the stock links (bushing material, whatever)
for a dual street/track car just run the alum 02-04 links. I run the alum up front and the front 01 steel in the rears. I don't run the plastic.
you can always check your corner weights and see where you fall
btw sperkins, I ran Khoi's old adjustable T1 bar at VIR this past weekend, and ran it at the softest setting and I got her right where I want her now. can't wait to go back to RA
Old 10-14-2009, 11:57 AM
Z06cool
Z06cool's Avatar
.... I ran Khoi's old adjustable T1 bar at VIR this past weekend, and ran it at the softest setting and I got her right where I want her now. can't wait to go back to RA
You know it'll cost you extra if my parts actually improve your time....
Old 10-14-2009, 12:28 PM
sperkins
sperkins's Avatar
No kiddin. I wonder how that setup would be on my stock Z51 springs?
I too took some parts from Khoi's car, but I doubt that brake ducts and a oil catch can is gonna shave time for me.
Old 10-14-2009, 12:39 PM
drivinhard
drivinhard's Avatar
I have his 2 cat H pipe, hardbar camber blocks, rear T1 bar, his traqmate, and his trailer.
Khoi, you might as well just give me the EVO and your bank account #'s to
Old 10-14-2009, 12:45 PM
sperkins
sperkins's Avatar
Dang - I didn't know sponsors were allowed in NASA.
Old 10-14-2009, 12:51 PM
Z06cool
Z06cool's Avatar
Cooler brakes = less fade = better braking = faster times..
Old 02-27-2010, 01:23 AM
Wicked C5
Wicked C5's Avatar
St. Jude Donor '04
Any one else want to chime in on this?
Old 02-27-2010, 04:14 AM
gkmccready
gkmccready's Avatar
What don't you like about the current handling? What are you expecting from the switch? The Pfadt coilovers like big bars but I'm not sure how much bigger the T1 bars will be compared to the Hotchkis.
Old 02-28-2010, 10:15 PM
jmorgan07z06
jmorgan07z06's Avatar
Keep the T1's and by the LG quiet endlinks. They are adjustable. I bought the LG G1 sway bars which are basically the same thing as the T1's and kept my stock endlinks. I could hear the rear sway bar banging around as I drove down my alley at a low speed. There was very little noise otherwise. I recently installed the quiet endlinks and all of the noise made by the rear sway bar was gone.
To T1 Sways or Stay with Hotchkis?
Quick Reply: T1 Sways or Stay with Hotchkis?
