Fehan comments re: GT2 roll cage
Old 10-20-2009, 02:19 AM
mousecatcher
mousecatcher's Avatar
Default Fehan comments re: GT2 roll cage
From 11/09 Racecar Engineering:
When Corvette [sic] first developed the C6.R it employed a steel chassis, which was not from the original base model. However, the new car uses an aluminium frame [per ACO and FIA GT2 rules].
The problem was, mating a steel rollcage to an aluminium chassis was not something GM racing was happy doing. 'It simply didn't provide a level of safety that met GM Racing's stringent standards,' explains Fehan. 'Consequently, we have developed a proprietary installation method that is consistent with GM's commetment to driver safety.'
'Analysis and physical testing of structural components suggest that this is the safest GT car on the track. We carried over the energy-absorbing panels in the doors, the door bar structure, the crush structure, the right-side safety net and other safety features from the GT1 Corvettes. These are not mandatory, but we chose to add those components at a considerable cost and weight disadvantage because driver safety is our top priority.'
Of course the weight disadvantage part is hooey but the rest is interesting, esp. re the rollcage installation.
Old 10-20-2009, 06:50 AM
rfn026
rfn026's Avatar
Typical Doug. He strings a bunch of words together but doesn't say anything.
Richard
Old 10-20-2009, 08:17 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Pics? I would like to see some details.
Old 10-20-2009, 10:13 AM
Tom03Z06
Tom03Z06's Avatar
Richard
Old 10-20-2009, 10:34 AM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
Old 10-20-2009, 10:37 AM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Originally Posted by drivinhard
Old 10-20-2009, 10:47 AM
AU N EGL
AU N EGL's Avatar
Old 10-20-2009, 11:10 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Pratt & Miller is not going to post pictures of their "proprietary installation method".
__________________
Contact:
(e) zach@katechengines.com
Old 10-20-2009, 11:11 AM
Katech_Zach
Epic.
Old 10-20-2009, 11:28 AM
Lancer033
Lancer033's Avatar
why not share the trick so your customers can install a cage safely too if that's true.
Old 10-20-2009, 11:50 AM
davidfarmer
davidfarmer's Avatar
I wish they would weld in threaded billet reinforcements at strategic locations in the aluminum frames, like they do at the suspension points..........
Old 10-20-2009, 12:55 PM
TLGunman
TLGunman's Avatar
Check out the latest issue of RACE TECH magazine, they have an article that explains a bit more, on how the cage was attached to the chassis.
Old 10-20-2009, 01:05 PM
L98Terror
L98Terror's Avatar
or you can get this one free
http://www.racecar-engineering.com/a...scription.html
Old 10-20-2009, 01:15 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Great article
To Fehan comments re: GT2 roll cage
Quick Reply: Fehan comments re: GT2 roll cage
