Grand Sport in T1
Old 10-20-2009, 11:45 AM
clubracer6
Support Corvetteforum!
clubracer6's Avatar
Default Grand Sport in T1
Since the Z51 option has been replaced by the Grand Sport model, which 2010 Corvette is eligible for T1? I would assume just the base coupe, but don't know for sure.
If the Grand Sport is or will be eligible, which it should be, then you could update your C6 to those specs, including the Z06 6 Piston brakes?
Old 10-20-2009, 03:37 PM
wtknght1
wtknght1's Avatar
http://forums.corvetteforum.com/auto...te-brakes.html
Old 10-20-2009, 03:52 PM
clubracer6
clubracer6's Avatar
Thanks for this, but I have been following that post as well... Did I miss something in there about the GS model being eligible next year and if yes, can we update to its specs?
Old 10-20-2009, 04:58 PM
BuckeyeZ06
BuckeyeZ06's Avatar
Does the GS have fender flares that allow larger rear tires? Say 335s?
Old 10-20-2009, 05:01 PM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Yes it uses the Z06 Flares so bigger tires will definitely fit.
Old 10-20-2009, 05:02 PM
clubracer6
clubracer6's Avatar
Yep, they have Z06 rear fenders...
I have been looking through the rule book and past FastTracks and can't find where even the 2009 was classified.
Old 10-20-2009, 05:16 PM
95jersey
95jersey's Avatar
you can fit 345 on the rears!
To Grand Sport in T1
Quick Reply: Grand Sport in T1
