9" or 10" wide rims?
Old 10-27-2009, 09:21 PM
Astrodokk
Astrodokk's Avatar
Default 9" or 10" wide rims?
275/50 or 60/15's on what rims?
I have the option to buy 4 used Enkie 9" wides w/ 3" backspace or 8 & 10 chrome Rallys w/ 4" backspace (would have to use adapter). Would that size tire be OK with 9 wide, or is 10" better? The Einkies are expensive and very light, but I can get them for 175. 120 for the 4Rallys.
Old 10-28-2009, 12:37 AM
69autoXr
69autoXr's Avatar
Both tires would be fine on either the 9's or 10's. Probably not much noticeable difference between the two wheel sizes, but the light weight of the Enkei's will be a bigger advantage.
Quick Reply: 9" or 10" wide rims?
