Raybestos ST43 - What can I expect?
I'll be putting a set of used 4 piston Brembos, F & R, on the C5Z soon. I bought these from a Forum member, and they came with a mid-life set of Raybestos ST43 pads. In the past I've tried Carbotech XP10, Cobalt XR2 and and Hawk DTC60 on stock calipers. With the high cost of pads for the Brembos, I need to run the ST43's out. Sales brochures are one thing ... every mfg. says long life, rotor friendly, high initial torque, good modulation, blah, blah, blah. But what can I expect real world from the ST43's as compared to these other pads? Thanks for the input.
Bob
Bob
I ran them as padlets on my first C6-Z06 and as I recall they were very aggressive and made lot of noise if used on the steet. They should be fine. JD
Former Vendor
NOT a street pad. They are a track only application. When used there they will exhibit the qualities described. When used on the street they will be hard on rotors and not terribly effective as they are designed for much higher heat applications.
You will not be disappointed in the ST43's performance on the track!
You will get 3x the life compared to the Carbotech front XP12 and rear XP10.
I am not knocking Carbotech just giving you the facts on pad wear.
Oh, and I was a big Carbotech fan and when all my other track buddies changed over to ST43's they trippled their pad life and I finally
decided to change over to ST43's and guess what I trippled my pad life too.
BTW - PFC-01's are comparable to the ST43's in terms of pad life.
Ask me how I know
All three compounds - ST43's, Carbotech and PFC-01 were all about the same on rotor wear.
Hi Bob
Ask me how I know
Ask me how I know
Carbotech IMO has great products but their pads just don't last as long as the other two pads. One could argue that they initially cost less which true but in the end they cost more because you have to changed them 3x as often.
BTW - It's been my experience the DS3000 have the same pad life as the Carbotech so I don't use them anymore either.
If I had a choice to either run Carbotech XP12's or DS3000, I would choose Carbotech because their compound is non corrosive
My experiences with the ST43's were impressive as well, the only negative is the initial cost. I used them at Laguna Seca; the PBR calipers deformed but the pads never faded! These are high end racing pads; I believe they were used by Joe Gibbs Racing on Tony Stewart's car a couple of seasons ago(correction, they used the ST41's.)
ST43 and Carbotech in regards to stopping power, I'd call it a tie but if I were pressed for only one winner, I'd have to give the win to ST43.
I ran these at Thunderhill and they worked perfectly.
A month later I used these @ Infineon and the braking power was super but the noise was unbelievable. They didn't screech , they SCREAMED! My friends in the grand stands said they could hear me going into every corner on the track. Maybe these things did not get hot enough @ Infineon as they did @ Thunderhill. In one week I'll try them again @ Infineon again and maybe I'll put a sock in my brake cooling lines to keep them hotter.
Any ideas out there?
________________________________________ ________________
It appears you did not get the pads hot enough but as a reference point, if you were not doing sub 1:58 then most likely they just needed more temp. Either go faster or block the brake ducts with tape.
Rich
Bob
The bottom line......... don't let the dust get wet and then dry on its own, if you do then get it washed off as soon as possible. Over time, you will be glad you did. Some folks use black rims because it hides all the dust but even so, I'd still wash it off.
