Nitto 555 r2 tire pressure
Old 11-02-2009, 03:19 PM
DMARSHALL100
Support Corvetteforum!
DMARSHALL100's Avatar
Default Nitto 555 r2 tire pressure
Anyone got any guidance on tire pressures for the nitto 555 r2's? I thought I saw a thread on this recently, but can't find it. Running an 02z with 1.7 negative camber in the front and 1/2 negative in the rear.
Tks
Old 11-02-2009, 05:23 PM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
Hot pressure ~ 36/37 front, two pounds less in rear.
Front camber is about right.
You might want to go to 1.0 negative camber in rear.
Old 11-02-2009, 06:36 PM
GettReal
GettReal's Avatar
I started at 30f/28r cold filled with nitrogen and it got up to about 35-36f/34r hot
Old 11-03-2009, 06:52 AM
DMARSHALL100
Thanks guys. I am running negative 1 camber in the rear. Apparently, I just cannot type.
Tks again
Old 11-03-2009, 07:41 AM
JimbeauZ06
JimbeauZ06's Avatar
I've played with it a bit based on #s Mungo gave me, and based on hot pressures was generally starting way too high. Originally was starting at 28lbs - front I was coming off track about 39lbs hot. This summer on an average 85 degree summer day I start at 26 front & 24 rear and adjust. Recently at NJMP in the cold/wet I started at 30 front & 28 rear and barely ever got to pressure.
I just noticed that Discount Tire only has limited sizes available, fortunately they're the sizes I use 275 and 305. Anyone had any difficulty in getting? Still priced under $1k per set.
Also, I've got three sets of these in various states of wear and # of heat cycles. Oldest set probably has ~ 30 cycles on them and still have some meat on the shoulders. Are they toast or can I still get some days out of 'em?
To Nitto 555 r2 tire pressure
Quick Reply: Nitto 555 r2 tire pressure
