FS-LT1 Road Race Engine w/ Build Sheet
I am posting this for a friend of mine:
A Pro-Built Race Engine from TPIS:
LT1 Race Engine 561hp/490 ft/lb tq w/Canton Road Race Pan (Only the
National Championship Race run on it.. so its VERY fresh still)
Complete with accessories (Alternator & power steering pump and Electric
Water Pump)
LTCC Ignition System (this eliminates the prone to failure opti-spark)
Tuned - Programmed computer
Shorty Headers & custom Y Pipe to clear the canton pan.
All for Just $7000.00
Here are some of the Engine Details
383ci
561hp/490ft lb tq
11.6:1 Compression - Balanced and blueprinted
(In my car puts 464 RWHP w/shorty headers)
GM 4 bolt Main LT1
Lunati 4340 Crank
ACL Performance Engine Bearings
Cloyes Timing Chain
Comp Cam Hydraulic Roller Cam 241/246 .580 lift int/ .580 lift exh
Oliver Con Rods
ARP 2000 Bolts
Mahle Flat Top Pisotns with Mahle C clip pins
Hastings Rings
Comp Cams chrome moly 7.2" Pushrods .080 wall
Fel-Pro Head Gasket
GM LT4 Heads Ported intake port 200c
5/16 Intake Valve 2.020
5/16 Exhaust Valve 1.6
Comp Springs 1.540 Dual Springs
Retainers - Comp 5/16th Superlock Titanium
Comp Cams Pro Magnums
Canton Road Race Oil Pan
Engine will come with the Spec Sintered Iron Race Clutch and the matched
Aluminum Flywheel.
Water Pump)
383ci
561hp/490ft lb tq
GM 4 bolt Main LT1
Lunati 4340 Crank
Cloyes Timing Chain
Oliver Con Rods
ARP 2000 Bolts
Hastings Rings
Fel-Pro Head Gasket
Aluminum Flywheel.
