FS: 90 Track/Street C4
Old 11-22-2009, 02:11 PM
Jomc
Jomc's Avatar
Default FS: 90 Track/Street C4
Here's whats on the car:
Suspension:
Z51 springs
Fx 3 revalved shocks (Morocco valving)
Poly bushings
32mm Front, 26mm rear, bars
J55 brakes with Carbotech xp 12 Front xp10 rear pads
cooling ducts to front brakes
Engine:
Ported and Siamese plenum
SLP runners
Accel base
52 mm TB
Cut lid with K&N filter
air pump eliminator
Turn One steering pump
Under driven pulleys
TPIS oil cooler with thermostat
TPIS coated long tube headers
3" dual exhaust with Dynomax mufflers
ZF 6 Trans. with B&M shifter
Fidanza Alum. flywheel
Carolina clutch stage 4
Kirk Racing rollbar installed have rest of cage not installed
2 sets of 90 wheels one set with GSC's
other set no tires
2 sets of 91 sawblades one set with V710's 8 heat cycles
other set with unknown cycled Victoracer's
Have all original parts removed from car except for plenum, TB and main cat.
Now the bad Head gaskets are leaking oil to the outside of engine, no oil in water though. Car runs fine just leaks oil.
69K miles
Asking $6,500 Firm
Cell- 252-469-5616
Home- 252-641-1086
Email Jom86@aol.com
Old 11-23-2009, 05:24 AM
worldsaway
worldsaway's Avatar
Great price! Good luck with the sale.
Old 11-25-2009, 07:27 AM
Jomc
Jomc's Avatar
Thanks!
I am willing to help with delivery of car up to 500 miles.
Old 12-04-2009, 06:31 AM
Jomc
Jomc's Avatar
Default Sold
Car is sold. Thanks Myles!
To FS: 90 Track/Street C4
Quick Reply: FS: 90 Track/Street C4
