ANNOYING TC/AH/TMPS sensor crap on all C5/C6 Corvettes
1 Post
Hi Guys,
I'm sure we all have experienced the same annoying traction control/active handling crap (at least for racing) that we have to remember to manually turn off before heading out on track....
I refuse to believe there is no way to permanently turn all this stuff off once and for all as I personally have been screwed by this annoying system more than a few times....works well for saving your a$$ on the street but GM or "others" must have a way to turn all this off PERMANENTLY?
I understand the C6 is even more annoying than the C5 due to the TPMS sensors and the fact that you cannot turn off the C6 while moving??
Anyone know of a way to turn this all off permanently aside from me designing a custom circuit to do this externally (automatically via button)?
Any help would be appreciated!
Thanks ya'll!
Thanks ya'll!
I understand the C6 is even more annoying than the C5 due to the TMPS sensors and the fact that you cannot turn off the C6 while moving??
I think if you look around Google you'll find a couple of places and people that offer the 555 timer based auto-all-off AH/TC gizmos. Mostly for C5s, though.
ATI Performance engineering makes a electronic widget that will have the active handling traction control disabled unless you want to turn it back on....It leaves the system "off" instead of "on". I think that it actually remembers what it was when the car was turned off....
It still uses the "button" for the AH/TC , so you need to make sure on your particular car that the factory system is operational....
I think that I have one of the ATI pieces that I never used.
1 Post
Is there not a way to turn all this stuff off permanently with a Tech 2 programmer or something?
Unfortunately I do not have a dash cluster (DIC) anymore so I cannot see what mode I am in AND my button does not seem to do anything for some reason...
Former Vendor
Randy
Wayne....fix the button and all will be OK.....My car has the button, it works, and I dont have problems. With your car if you ever run in the rain the TC is not gonna be the worst thing to have.....I need to put my TC on a momentary switch for the straights only in the wet.....
Hi Guys,
/Hakan
GM racing gave it to me. It was a PCM only swap, so I know the BCM etc wasn't modified.
My contact there has retired, so I don't have any leads on who actually did the programming.
Received 8,928 Likes
Wouldn't pulling the fuse work just as well? The system doesn't work without electrical power.
Bill
Bill
