wheel questions....
wheel questions....
I am new to vette's, just got a 00 frc to be my weekend/fun/roadtrip and track car. I have done some track stuff, 2 days..lol.. Ideally I would like to do 4-5 track days a year, but this depends on time and money. SO street use would be higher than track for the next 2-3 years easy.
Anyway, I am looking at a set of wheels. These wheels will do both street and track. I understand many people don't like repro's for track, some do. As I am on a limited budget, I am trying to find if anyone is running repro's on the track with good or bad experience? Like a LW&T or similar is the wheels I am looking at. Ideally I would have 2 sets of rims, but for now, the budget does not allow it.
And FWIW, I am looking at 18x9.5 all around with 265 F and 285 R. I don't have active handling, but from the threads I have read I could still have TC issues with a square setup, so this gets me close, but maintains some diameter difference front to rear.
If this appears to be a bad idea I would happily listen to other suggestions
TIA
TIA
Most will say to stay away from repros because they are heavy and to stick with OEM wheels. Speedline Z06 wheels can be run square with the fronts (17x9.5) or rears(18x10.5) and are pretty easy to find on here especially the fronts.
The cheapest wheels are wagon wheels and you could run the rears (18x9.5) square if you don't mind the look. I got a set for under $100 and painted them black.
Do a search in this Forum for Speedline and you will find a bunch of info.
I run a square setup. No traction control issues. Same PCM and EBC as your car.
I have 4 18x9.5 wagon wheels with 285/18 Nitto NT-05's that I have run.
I have 18x10.5 now with 660/295-18's Dunlops I run now.
The wagon wheels with Nittos are for sale. about 50% tread left.
I think sperkins and jason were looking to unload some 17x9.5" Z06 wheels this weekend at RA. check one of the RA threads and PM them, you could come pick them up being local
you can run them square (I have never had TC issues with square), 275/40/17 fits nicely, and that's a hugely popular size for scrubs, and you can get nitto 555R2's in that size brand new for like $179 from discount tire.
I'd buy used OEM Z06 wheels before I'd buy repro's, the difference in weight is huge.
18x10.5" rear Z06 wheels are also an option, but you'll pay more.
And I want the wheels that I drive around on to look good.. I know.. I am a pretty b*tch! LMAO.... I know... track wheels don't need to be pretty though.
And I sent you a pm bout the wheels...
I know I have read several threads about people having TC issues when pushing the car in the curves when square.
But, again, thanks for the input.
