Driving suit
Driving suit
Any recommendations on a driving suit? I have someone that is taller than average so the off the shelf ones are too short. Wants a two piece suit.
G-force is reasonable on custom fitted ones. You fill out a sheet with about 20 or so measurements. They send you a test suit (made of plain material) to check fit. You tell them any adjustments you want made and then they make the suit for you.
Quick, easy and reasonable. And they were pleasant to deal with.
I had no problems getting two custom suits done.
Get at least a double layer SFI 3.2A/5 rated one with the Highest TPP rating you can get. TPP is how long it withstands heat and flame. G-Force makes good affordable stuff along with Crow, Ultrashield, and even Simpson. Check out the SFI website also it has good info on everything that has SFI ratings. http://www.sfifoundation.com/
