Vintage 332 SBC chev engine (Group 6)
Old 12-17-2009, 02:10 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Default Vintage 332 SBC chev engine (Group 6)
This low hour (6) .040 327 race engine was built from a 1965 chevy block. Line honed, decked, bored and honed. Then the crankshaft was nitrated, balanced, and prepped. Eagle rods with the upgraded ARP bolts were balanced and installed on the JE pistons. The heads were done by Lockerman's head service, new valves install, with a competition valve job. CompCams valve springs were installed because of the 268-268 .580 lift camshaft on a 108 LSA. A rev kit was also installed for high rpm use. With the current setup the engine is at 12.7 compression. There is also 1.6 Comp rockers installed. The pan is a wet sump road racing pan, and new oil pump were both installed for the sale (was a dry-sump). This engine was built and used for Group 6 in SVRA and other vintage race groups. If you have any additional questions please let us know!!!!
$3500.00
We are able to ship anywhere in the world, please ask for a shipping quote.
Doug 763-477-9272
Old 12-17-2009, 02:14 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Old 12-17-2009, 03:05 PM
bjm
bjm's Avatar
What is randy building for 2010? Big Block maybe??? If that is the case I won't be able to beat him anymore!!!
Old 12-17-2009, 03:33 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
He is going to be running a SBC that was in the car last year. This engine for sale is for the tire budget.
Randy
Old 12-17-2009, 05:55 PM
63Corvette
63Corvette's Avatar
Randy,
Nice engine....and I could use it (track or spare) BUT our vintage rules require STOCK stamped steel rockers. Rollers are NOT allowed. So....what kinda reliable rev range could I expect with stock rockers?
(PS we will be at MSR on Saturday for suspension track testing)
Thanks,
Old 12-17-2009, 07:18 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Originally Posted by 63Corvette
Randy,
Thanks,
A comp cams stock like rocker would be good to 6800 rpm or so. If you have to run a (stock stock) one then the spring pressures would be too much and cause issues. Give Doug a call here at the shop if you have any more questions.
763-477-9272
Randy
To Vintage 332 SBC chev engine (Group 6)
Quick Reply: Vintage 332 SBC chev engine (Group 6)
