uneven rotor wear
Old 12-22-2009, 12:14 PM
LEAVINU
LEAVINU's Avatar
Default uneven rotor wear
Hey guys,
I installed a second set of some very high end rotors 2months ago and noticed the other night that these rotors are pretty much shot. I have NOT done any tracking with these rotors as of yet. The rotors went on the car, made a trip to FL for a wkd and have since only seen daily driving conditions to and from work.
I have contacted the folks that I purchased the rotors from and rather not say who or which brand the rotors are until they get back to me.
However, I am posting to see what others think of my situation. So now to the condition of the rotors:
Driver side front is a slotted rotor that is now solid on one half with very slight slots still remaining on the other half. Rotor is dead straight, not warped, and no major grooving.
Passenger side front still has slots all the way around but noticeable wear to the rotor. the slots are not nearly has deep as I would expect them to be with the few miles on the car.
Driving and braking is perfect. There is no noise, no shaking or vibration, no nothing. The car stops as it should from any speed.
The rotors prior to these were of the same make and style but didnt wear anything like this. They had been on the car for a year or so under very had driving and just had their time. Now these rotors are just shot!
Hope this all makes sense and someone can provide some insight to this?
Old 12-22-2009, 01:08 PM
froggy47
froggy47's Avatar
You need to tell us what pads are on the car to start. Wife, g/f drive the car? Automatic? Could be when you had them installed the calipers & hardware were not lubed correctly (or even installed correctly) and some brake drag is happening.
Old 12-22-2009, 02:07 PM
LEAVINU
LEAVINU's Avatar
Cobalt pads
Manual 6-spd
nobody drives the car other than myself
pads were lubed as necessary on edges
car in the air, spinning the wheels/rotors does not indicate any abnormal drag.
Old 12-22-2009, 03:08 PM
froggy47
froggy47's Avatar
Originally Posted by LEAVINU
Cobalt pads
Manual 6-spd
Puzzler.
My use is never normal, I expect to do rotors every two sets of pad.
For my other cars/trucks I have gotten 50-60 k miles on rotors (2 to 4) sets of pads & sometimes the rotors never seem to wear
Let us know what happens.
Old 12-22-2009, 03:16 PM
gkmccready
gkmccready's Avatar
Assuming you're a C6 non-Z06 with the stock caliper... I'd double check the calipers are actually moving on the slide pins and the slide pins are properly lubed and aren't bent or otherwise jammed.
FWIW, when I ran Hawk Blues/Blacks on another car I can tell you that they consumed rotors very quickly if you used them when they weren't up to temperature... so if you're running race pads on the street you may end up seeing excessive wear...
Old 12-22-2009, 03:28 PM
froggy47
froggy47's Avatar
Do cobalt pads come in different compounds? I have never used them but I think some guys use them for track pads & they are going to be harder on rotors than stock or ceramics.
Old 12-22-2009, 03:32 PM
gkmccready
gkmccready's Avatar
They do have different compounds and the last time I asked them they told me they did NOT have a streetable compound for the C5/C6.
Old 12-22-2009, 03:33 PM
LEAVINU
LEAVINU's Avatar
One of the first things I did check and it does seem the calipers are moving as they should. My first thought was the caliper had to be sticking and it doesnt seem to be.
When I bought the new rotors I bought new pads as well. Had a very good phone call with the distributor and explained to him my driving style so I'm pretty sure the setup is ok for my usage.
Old 12-22-2009, 03:34 PM
LEAVINU
LEAVINU's Avatar
I hope thats not true cause thats different from what they told me.
Old 12-22-2009, 03:45 PM
Nimo
Nimo's Avatar
St. Jude Donor '08-'09-'10
Cobalt pads
Manual 6-spd
I had the same happen when I didn't swap my XR1 pads after a track day - 2-3 weeks of street driving ruined the rotor. My have been a bit aggressive as I was breaking in a new clutch.
My conclusion was that track pads probably wear your rotors more when colder than what they are designed for - not a good street pad.
- This was with stock C6Z calipers and Coleman rotor rings.
/Nik
Old 12-22-2009, 03:58 PM
gkmccready
gkmccready's Avatar
I emailed Cobalt directly, I never talked to a distributor/vendor. Which compound did they give you?
Note that still won't explain single sided wear... I'd still look for a hung up pad or slider.
Old 12-22-2009, 04:01 PM
AU N EGL
AU N EGL's Avatar
Your rotors will not stay nice and shinny as the guys over in the general sections ( who never drive their vettes) want you to belive
Old 12-22-2009, 04:06 PM
63Corvette
63Corvette's Avatar
My Stoptech rotors are now four years old with street driving and one (1) track session. They are not apparently wearing at all with Pagid Blue pads.
Old 12-22-2009, 05:10 PM
RedLS1GTO
RedLS1GTO's Avatar
I've had the same set of rotors on my 02Z for 3+ years and 40,000 miles of street driving. About half of that was with ceramic pads, and half with the stock Z compound depending on where the sales were. No issues from switching around at all. Just put on a new set of pads and they still look almost brand new as far as wear is concerned.
Old 12-22-2009, 07:21 PM
froggy47
froggy47's Avatar
Here's a link to the Cobalt (Racing Brake) site, at a brief look it seems they are all race pads except the very last (introduced in 2009) which might be ok for "occasional" street use.
http://www.cobaltfriction.com/compounds/
I'm thinking you got some race pads, dude.
One of the main characteristics of race pads is to be "not" rotor friendly.
Old 12-22-2009, 08:00 PM
LEAVINU
LEAVINU's Avatar
You are correct in your findings, I have the CSR pads. One thing to note too is that the pads are in mint condition.
So I spoke to my brake guy and we are both baffled but he is a true professional and is helping me out with a new set of rotors. I will go to a street pad/rotor setup and swap to cobalt pad and race rotor setup when necessary.
Old 12-22-2009, 08:22 PM
froggy47
froggy47's Avatar
Glad we could help,
You can keep the new race rotors on all the time & just switch from street pads to race & back. Pad change is ez, rotors require the removal of caliper (ugh)But you would probably need to "clean" the rotors inbetween, although I have done it without the cleaning. When I swap in the race pads, their abrasion cleans off the transfer material from the street pads. But going the other way (race pad to street) I would probably do the clean, it's not hard, garnet paper & brake clean fluid. But if you go ceramic then clean between switches both ways so as not to contaminate either pad. Be careful. Some pad materials (from different pads) are mixable & some NOT.
To uneven rotor wear
Old 12-23-2009, 12:44 AM
rustyguns
rustyguns's Avatar
- This was with stock C6Z pads and Coleman rotor rings.
/Nik
Old 12-23-2009, 10:48 AM
brkntrxn
brkntrxn's Avatar
I skimmed through this thread and did not see anything about seasoning the rotors when you installed them. Did you?
Old 12-27-2009, 11:28 PM
Dirty Howie
Dirty Howie's Avatar
I used to lube the pins on my C5 but have never lubed anything when swapping pads on the C6Z. Should I be ???? I thought it was not necessary.
DH
Quick Reply: uneven rotor wear
