What seats in a C6?
What seats in a C6?
Wanted to race with the local PCA at an HPDE this coming weekend, but they don't allow stock seats with race harnesses.
For those of you who are larger framed, what seats will work with the C6 and still allow the airbag system to work?
Nothing extravagant please. Working man's budget.
Thanks,
Ken
Thanks,
Ken
Received 8,919 Likes
I have the Ultrashield Road Race Deluxe seat. It is mounted on Hardbar rails which work very well. However, if you want to avoid playing around with the underseat carpet so the rails will fit over the seat wiring harness the Pfadt seat rail may be a better solution. To get the Hardbar rails to fit over the wiring harness I pulled up the carpet and cut out the underlayment in a couple of places so the wiring harness wouldn't be squeezed as much. If you have side air bags when you pull the seat the airbag light will be lit but the front air bags will still be lit. Make sure the telescopic steering is set where you want it before pulling the OEM seat as it will not move once the seat is pulled.
Bill
Bill
