shelf life of brake fluid
I remember reading about shelf life and oil. I think it was an engine oil article. I want to say it didn't want you to leave it on the shelf more then two years.
Opened brake fluid gains around 3.5% moisture per year.
A quick example, Wilwood Hi-temp unopened 570, 3 months-499, 6 months-427.
Source: http://evilplastic.com/bfluid.htm
IMO if the seal is good I don't see an open can gaining a lot of moisture!
That all makes sense, I'm just relaying what I've heard as far as using opened brake fluid containers. Actually, you've prompted me to look into it further...hmm...
The metal cans vs plastic probably make a difference.
I finished off some ATE cans (metal) I bought in 2002 this past year.
I have never trusted the plastic stuff to last a long time.
I emailed ATE about this same issue about a year ago approx. and this is the reply I got:
Life expectancy:
All Brake Fluids
With temps between -20 C and 40 C up to 5 years in the initially closed tins.
* once opened, use within 1 year
Brake Cylinder Paste
With temps between 0 C and 40 C: 3 years
Plastilube
With temps up to 40 C: max 2 years
Datecodes on the product:
Brake Fluid Container: Day it was filled marked as day XXX plus year Y, e.g. 0787 = 78th day of 2007
Brake Cylinder Paste: Stocking period max, e.g. 09/09 = max September 2009
ATE Tech Support
800-265-1818
Life expectancy:
All Brake Fluids
Plastilube
ATE Tech Support
800-265-1818
Castrol SRF went from metal to plastic containers a few years back I guess it's $$$$$$
Life expectancy:
All Brake Fluids
Plastilube
ATE Tech Support
800-265-1818
Life expectancy:
All Brake Fluids
Plastilube
ATE Tech Support
800-265-1818
Seems ok.
Metal can with a plastic pull tab seal.
