Traction control button
I'm stripping the interior of my 99 coupe. I want to remove the center console and dash bezel but need ideas on what to do with the TC button.
there are multiple wires on the back of the switch. I was afraid to tear into the housing to see about pulling the switch out. I figured it would just be a couple of wires but I think there are 6 wires.
I don't have active handling. I'd like to keep TC for those wet track days.
What have you guys done?
The help is much appreciated.
not sure about the wiring but I would not be using TC on the wet track - you don't want it to cut the power in a turn when you are not expecting it to. it works OK in a straight line but gets a little crazy in the corners
Location: If you don't weigh in you don't wrestle Road America
All you have to do is install a mometary switch (radio shack) from I believe the green wire to ground. I think it was the second wire in.
Check out this thread, pretty much the info you're looking for.
http://forums.corvetteforum.com/auto...sole-pics.html
