lap timer
I use a traqmate and I think that it works great and is very easy to use. Here is some video with the data.
http://www.youtube.com/user/Z06no881.../3/YSGMJP9u9vg
With the Traqmate system you get great data about your track sessions, but you only get the synched video if you have video camera and the TraqStudio software that integrates your data and video.
If you don't have video, you'll open up TraqView on your computer and get info like you see below:
If you have a video camera you can get TraqStudio software and see synchronized video next to all the data:
With TraqStudio you can select a few laps and have the software write video files that you can upload to youtube, streetfire, vimeo, etc. TraqStudio can use the Traqmate data to put a "dashboard" onto your video. Try the links below to see the dashboard on the video:
There are some other really great data-loggers that hook into your OBD port to pick up info from sensors in the car. With Traqmate you need to tap into wires to OE sensors (tach signal, throttle position, brake light wire, brake pressure sensor, oil pressure, etc.) or add sensors and then run the wires to your Traqmate unit.
Bob
Bob
After a session you can get a bunch of data from the DU by scrolling around, and I think you can view lap times - but it's just a very small window on the unit.
Or, if you take a laptop to the track, you can plug your DU into a USB port on your laptop and open up the session to really get all the data that you want to see to really analyze your session. Below is a screenshot of TraqView on my computer, and I've opened the "Setup" window to select all the parameters I want displayed when I close that window. You can see that all the lap times are displayed with the fastest lap highlighted in green.
Bob
Take a look at RLC racing's website regarding the Track Commander, Micro pod sport and Micro pod lite models and compare them to the traqmate. I purchased the Micro pod sport. I haven't used it yet but I think it offers a few options other systems don't.
Track timer?
I use this for track timing, very happy with it...
http://www.vboxusa.com/performancedr...ormancebox.php
Significantly cheaper than some other sytems and it does what I need.
Be good,
TomK
Be good,
TomK
iPhone apps
I went out to dinner with my wife tonight, then when she went shopping I was checking email and surfing around on my iPhone.
I remembered seeing some apps a month or so ago that do some data logging. I did an app search tonight and came up with a few, and this one might be the best of the lot:
http://forum.iphoneworld.ca/iphone-a...app-21615.html
If you have an iPhone, do an app search for "lap timer", "data acquisition", "track days", etc. and you might find a few more. I see that one in the link above is $11.99, and a couple others that might not be as capable are either free or very cheap.
Does anybody have any experience with these iPhone aps???
Bob
Bob
Track timer?
Be good,
TomK
Be good,
TomK
RE iPhone, I have Harry's lap timer, and while I really like it, the only time I had a comparison (NASA TT Time Trial) the results were waaayyy off. I'm hoping to mount it better this year and see if I can get better data, but so far it's been a disappointment.
It takes one lap. You push a button on the start/finish line, and it gives you the time when you cross it again.
Tutorial page for the PBox...lessons on the bottom of the screen- should give you an good idea if it would work for your needs.
http://vboxusa.com/performancedrift/tutorials.php
I'm leaning towards this one. Like you say: does what I need and competitve price.
Track timer?
Be good,
TomK
Be good,
TomK
Also how was the shipping, cost and quickness ?
I am not exactly sure what it was but a guy at one of my events had a unit that basically looked like a stop watch for about $300.00
He just put it in his center console and then was able to download all the data, inlcluding track map to his laptop.
Somebody else on here might have some info on it.
