Questions about 6 point harnesses
I would like some opinions on 6 point harnesses. I am installing Hardbar seat rails with Hardbar harness bar and a Sparco Corsa seat. I also plan on using a Defnder head and neck restraint system. So do I need a harness that is HANS compatible? I think I understand that both anti-sub straps come through the bottom of the seat but how and where do they position across your legs? What brands are preferred and other things to look for before buying? Any pics would be great. Thanks, Nathan
the belts should not need to be "hans specific". I agree that 6-pt is probably safer, but I miss the days of 5-point belts. MUCH easier to latch and more comfortable when your NOT crashing.
Schroth makes Hans compatible versions of their belts. For instance, the Profi II-6 I have also comes in a HANS version where the shoulder straps are 2" wide instead of 3". This allows the should strap to more correctly ride along the HANS collar as opposed to overlapping it a little bit with the 3" shoulder belt.
-Kevin
-Kevin
That's exactly right. A "proper" shoulder harness belt for use with a HANS is 2" wide, instead of 3. I doubt it would matter much, but those are the facts.
As far as 6-point vs. 5-point...either way, I highly recommend a good "cup!!!" It makes driving much more comfortable!
Thanks for the feedback guys. I think I was making the six point harness harder than it is. I called Simpson yesterday and found out that the bolt in harness the hardware can be removed from the shoulder harness and used as a wrap around. Also was worried about being HANS compatible turns out 3" harness works just as well as 2" HANS compatible. It sucks that safety and design doesn't always mean as mush as good marketing.Because I was a little confused about what to buy 2" vs. 3" shoulder harness. I've used Simpson stuff before in my dirt car and never had any issues.
Yes you got it right. But you should try a hans with the different belt designs. Some people have very boney shoulders. In my experience and talking to people the comfort of hans with the different belts goes 4 shoulder best, 2" next, 3" worst. 90% of people have never even seen a 4 shoulder and I bet you dinner no one near you has one to try. Most people use 2" belts with hans and are very happy and seems to be the best comfort compromise. I use the 4 shoulder and it feels like I'm not wearing the hans at all. Safetywise 2"=3"
Former Vendor
Take a look at this one, very comfortable and the HANS won't be buried in your collar bones upon impact:
http://finspeed.com/8PT-Double-Shoul...NS-04728TW.htm
Finspeed,
Very cool to see sparco making the 4 shoulder unit. Schroth used to be the only ones. Did sparco also adopt the hybrid cam for the 6pt individual subs? Thanks for posting this about this new sparco harness. It is also cheaper than the schroth unit
I have connected my 6 point sub belts through to the same anchors as the lap belts and fed them through the side holes in the seat. I sit on top of them and then latch them in.
Is this wrong ? Do I really need a new anchor point underneath the seat ? I thought you were supposed to use the lap belt mounting points.
Former Vendor
The sub-belts are attached to the cam by a t-bar, a hybrid cam variation is being tested. Let me know if you have any other questions.
Daniel
http://www.finspeed.com/
