Fuse #17 blows TAC module Throttle body
I race NASA ST-2. I first noticed engine running rough on left hand turns. Then engine quit. Will run, but only at high idle. Fuse # 17 blown.
Chevrolet dealership checked out, replaced fuse, said OK.
Next race 1st day, 3rd time out same thing.
GM speed shop checked out. Could find nothing. They replaced throttle body and ordered TAC Module part #12578953. Hopefully replacing both will fix. TAC Module is on backorder and no one knows when order will be filled.
Can anyone help me find a new or used TAC Module part # 12578953?
Thanks,
Pudge
Thanks,
Pudge
Location: If you don't weigh in you don't wrestle Road America
Try LS1Tech
Here's one thread when I tried the part #.
http://www.ls1tech.com/forums/lsx-pa...w-acc-etc.html
Or try pace performance
http://paceperformance.com/index.asp...&ProdID=198814
Or Summit Racing
http://www.summitracing.com/parts/NAL-12578953
Hope one of these helps
Or Summit Racing
If I were a gambling man (which I'm not) I would bet the problem isn't in the TAC. It is very common to replace components when doing this kind of troubleshooting. If the TAC was didn't work and everytime I put a fuse in, it blew then I would suspect the TAC. But the fact that it can run for a period of time (sometimes over an hour?) points in a different direction.
This is an intermittent short that blows the fuse which then causes the TAC not to work. There is a pink wire that runs from the TAC module to the fuse center under the hood. That pink wire runs in a bundle of wires which gets very hot at times.
I have pulled the wiring completely apart on my track car in an effort to remove weight. When I started doing this, I took apart wire bundles and found many wires melted together My thought is, this has happened in your case but not a complete short yet. When you take a certain corner and it cause the motor to twist a certain way it puts enough pressure/pull on that bundle of wires and causes the short.
I would also loosen clean and retighten all the major ground connections on your frame, just as a safety measure.
Which model 'Vette are you driving? My '07 Z06 started cutting out and running rough, and finally died, and threw a throttle body code, but didn't blow the fuse. Upon removing the air bridge, I found one of the hydrocarbon-collecting pads had let go from the inside of the air bridge (from oil that blew back out the TB, it ate away the glue) and jammed up into the throttle body butterfly valve! Something to check, just in case.
