C5 Road racing TR6060 ZR1 Spec transmission
Former Vendor
RPM Transmissions has completed the perfect road racing transmission for your C5 track car. The transmission is a brand new factory ZR1 transmission with 2.29/1.61/1.25/1.00/.81/.67 gear ratios. The OE Tremec helical cut gear set allows for quiet operation. The transmission is fully micropolished to reduce internal transmission temperature and allow for much quicker shifting. We also install bronze fork pads to keep the shifts firm and precise. We also utilize the factory transmission cooler pump with -6 AN pressure and return fittings for easy installation of a transmission cooler. This transmission is fitted with modified factory C5 tail housing and 27 spline main shaft so that it is a direct bolt in for your C5!
Pricing is $5395.00 outright
Factory 2.66 or 2.97 gear set ratios are available for $4395.00 outright as well.
