Header effects?
Header effects?
Recently the CRB allowed the C5s to upgrade to headers in class T1. I personally think it was a good idea. There's been a lot of debate regarding just how much extra power headers provide to both a stock vette and one running an already open exhaust.
I'd like to get some feedback from those who added headers to a car that already had an open exhaust (i.e. no cats, no mufflers, etc). I'm looking for actual HP/TQ increase numbers on a relatively stock LS1 or LS6 engine (between 350 and 425 rear wheel hp).
The other issue that came up was the sound level. I have a very strong feeling that adding headers to an open exhaust will send many C5 owners over the 104 db limit. If you have any of that info, it would be helpful.
I don't want to get into any arguments regarding "for" or "against" these mods; I'm just looking for raw, basic data. Thanks!
I ran stock headers on Friday with 368, 369 and 371 HP readings from the dyno. That afternoon we installed headers and did a retune and the car went to 414 HP/404 torque. I picked up 3.7 seconds on a roughly 1:50 second track on Saturday.
Aaron
Alright! It just isn't right to let this go on any longer. I am just yanking your chain... mostly Chris Ingle's.
None of us have done headers, yet. I bet we will in the next month or two though. We will report REAL results as soon as we get them.
Oli
im still running OEM '01 downpipes, with the dual pup cats and H pipe.. i was only hoping for 30HP... mid-range should definitely get a hand... maybe make up for the giant 3-4 gap.
this could be fun.
I did two modifications at the same time on my LS6 that already had a VaraRam air induction system and Corsa mufflers:
1) Crane 1.8:1 aluminum roller rocker arms and springs
2) L.G. Motorsports long-tube 1 3/4 inch headers, random technologies high-flow catalysts, and 3-inch X-pipe, thru the Corsa mufflers.
A chassis dyno run before and after the installation of these parts showed a 44 rwhp improvement.
hard to compare.. i think the vararam benefited a lot more from the headers than the stocker will
Location: If you don't weigh in you don't wrestle Road America
Joel
Never had a dyno, but I think I actually lost HP when I installed a full 3" catless Kook's system with straight pipes. I think it's just too much for my stock LS1. My bet is that my HP went down, but my torque improved.
-TJ
