DTCs with racing seats?
Old 01-31-2010, 07:09 PM
Dan Wendling
Dan Wendling's Avatar
Default DTCs with racing seats?
I heard rumor that a C6 will throw DTCs and limit performance when it detects a failed airbag! So if I replace the seats with a set of Arizen Racing seats, with no airbag what happens?
Old 01-31-2010, 07:42 PM
drivinfast
drivinfast's Avatar
I have the stock drivers seat with the airbag. 3LT package
I took it out unplugging all the harnesses and put in a Corbeau seat. No codes no DIC warnings. you get the idiot light on the airbag is all.
So on the seatbelts-- I had an extra female end from a generic install on my Honda. I bolted it to the racing seat for driving on the street.
If you have the telescoping steering wheel you can get the aftermarket wiring harness, take the box out from the stock seat and hook it up so it will work.
Old 01-31-2010, 08:03 PM
WNeal
Support Corvetteforum!
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
When I still had the airbag, all I got was the red idiot light and nothing else.
Old 01-31-2010, 08:13 PM
drivinfast
drivinfast's Avatar
The aftermarket harness will eliminate the airbag idiot light as well
Old 02-01-2010, 01:18 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Take the SCM & wiring harness off of your stock seat plug it in and throw it under the seat. No codes, no issues and every thing works.
To DTCs with racing seats?
Quick Reply: DTCs with racing seats?
