Pre-season DE & Racing reminders and info
Just cleaning up some of my links and wanted to remind all of you, and introduce any newcomers, to my info site. Good time to download new or fresh copies of my Torque Specs sheets, DTC lists, DIY guides, and anything else useful you might fine.
If you come across any dead links, or have any suggestions (YES I already know it's a crappy design, but I like to think of it as retro, like the new Camaro) please send them to me.
btw, been doing a fair bit of vinyl numbers and chassis work if you are in need.
Thanks!
David
http://www.davidfarmerstuff.com/
Thanks!
David
I have printed off your DTC and other guides and put them in my tool box that goes to the track. They make for great reference guides even if you bring the car's entire service manual. Thanks for putting them together.
btw, I have removable low-tac vinyl now. It is black, but we can overlay another color on top of it, like brkntrxn above.
I have a few more links I need to repair on my site, like the NAPA Weatherhead brake fittings. I'll try and get that fixed soon.
Premium Supporting Vendor
David,
Lots of good info, but nothing on snow removal?
I'm so sad that I can't go racing until several feet of snow either melts or moves out of my driveway...
Brad
Brad
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
Thanks!
David
Thanks!
David
Time to give the car a very good once over and get all the routine maintenance done from front to back, top to bottom.
Mine is ready except for the PS pump Danny needs to get installed.
Hopefully I have all the stupid crap fixed on my car and I can bring it to you in early spring and let you do my handling set up. I went thru some of your diy, but I think it might be something someone who knows what they are doing should do. I am doing VIR the 8th of March so hopefully I will have a better idea of when then. If nothing else, thanks for keeping your site up and running for everyone.
That's why I stopped using normal alignment shops.........I'd see all of the fancy laser/wireless rigs, but the people turning the wrenches had no idea what they were doing. Turning a wrench until the light turns green is NOT the way to set up a car!
Had a little time, so I removed the dead ebay link, and added links for the Weatherhead brake fittings.
Weatherhead at NAPA is a great source of OEM style brake fittings, in case you ever replace lines, install a line-lock/bias adjuster etc. It can be difficult to sort through the US/British/Japanese brake fittings, since they seem to be randomly mixed and matched at times. These catalogs help!
http://www.davidfarmerstuff.com/weatherhead.pdf
http://www.davidfarmerstuff.com/weatherhead2.pdf
and btw, I pulled the Vette out so that the SUN could soften up some of the stickers on the car for removal. I've found solar radiation can soften/loosen the vinyl even in cold weather, and makes them less brittle when you peel them off. Obviously I didn't see the weather forecast before it was too late!
I might not be out until April-May.
St. Jude Donor '10-'11
Just want to put in a plug for David ... when you stop by, please contribute a small amount to keep the site going ... a vital link to a vital pool of resources!
