335s on 10.5" rim?
Old 02-13-2010, 09:01 PM
Rob P
Rob P's Avatar
Default 335s on 10.5" rim?
Am i able to put a 335 on the stock rear c5 z06 rim? will this fit on the car without rubbing issues?
thanks
Old 02-13-2010, 09:27 PM
hamdog
hamdog's Avatar
Even if it fits, I wouldn't recommend it. I got 315 RA1's on mine and I feel there is too much play in the tire walls in hard cornering.
I belive the recommended width for 335's is 13"
Old 02-13-2010, 09:41 PM
subtlez28
subtlez28's Avatar
Are you able, yes.
For drag racing it would be ok. But like hamdog said, to much sidewall bulge is bad for cornering.
Old 02-13-2010, 11:00 PM
rustyguns
rustyguns's Avatar
thanks
no
Old 02-13-2010, 11:23 PM
froggy47
froggy47's Avatar
315 better.
Old 02-13-2010, 11:47 PM
trumper Z06
trumper Z06's Avatar
Using c5 Z06 rear 18 inch rims:
305/35/18 Hoosier R6's
315/35/18 Kumho V710's
check the width of the tire tread.
In either case... these tires will rub the inner fender, both front & back.
Old 02-14-2010, 12:27 AM
rustyguns
rustyguns's Avatar
do not rub on my C5
Old 02-14-2010, 05:59 AM
trumper Z06
[QUOTE=rustyguns;1573092774]do not rub on my C5 [/QUO
Depends on alignment...
and how TIGHTLY you turn the wheel.
On both my C5 Z06's
and the current C6 Z06...
We do glass in (repair) the inner fenders occasionaly.
Most of us using 18 inch C5 Z06 rims all around have set the car up
for the track.
Old 02-14-2010, 07:13 AM
AU N EGL
AU N EGL's Avatar
[QUOTE=trumper Z06;1573093486]
On both my C5 Z06's
for the track.
and some of us just cut out the inner wheel well liner.
Not all tires are the same width, measure them.
Hoosier 18x335/30 is 13.6" wide
Most others 18x335/30 are ~ 13.1" wide 1/2" difference.
but 10.5" rim would be better for a 305 and maybe a 315.
Old 02-14-2010, 09:43 AM
trumper Z06
YEP !!!
The Hoosiers for a given size are ~ 1 inch wider than
the Kumho's and most other brands,
when you compare than side by side.
Also some of the V710's have rounded shoulders which don't
need as much negitive camber.
Thereby enabling a "modified track/street" alignment which is much friendlier to your "street tires".
Over the past few years I've run full slicks...
both Goodyear & Hoosiers,
Rolex/CanAm Hoosiers with a longer lasting rubber compound,
Dot "R"... Hoosiers, Goodyear's, Michelin's and Kumho's.
You pay your money & make your choice.
Old 02-14-2010, 12:06 PM
TedDBere
TedDBere's Avatar
335s will rub on cornering, fwiw.
Old 02-14-2010, 09:01 PM
Rob P
Rob P's Avatar
thanks for the info guys
Old 02-15-2010, 09:38 AM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
They barely fit on my 12in rims
To 335s on 10.5" rim?
Quick Reply: 335s on 10.5" rim?
