Portable Air Compressors
Wondering if a portable compressor like the Porter Cable 6 gal. Pancake Air Compressor would allow for a few pressure changes?
Do most tracks (specifically Summit Point and VIR) have AC power available to recharge the tank?
http://www.sears.com/shc/s/p_10153_1...pressors#specs
Some battery jumper packs will also have a small air compressor and they will work too. I also carry a 7 gallon air tank that charges to 125psi.
If you really want to go a little insane you can purchase an eletric air compressor from Air Zenith and pipe it into a 5 gal tank. 165psi - 200 psi takes 40 seconds. I use 2 of them on my air bagged truck.
those portable 12v chargers do the job, and I have one, BUT they tend to pump a lot of moisture as well.
VIR charges for AC power, but you can use it occasionally without anyone noticing. If it's worth the hassle/cost, the one to reference should be fine. Filling tires is easy.
Hey, I just got a Harbor Freight flyer (Sunday's paper) with a coupon to get a 3-gallon, 100psi air compressor for $39.99. It is a small, squatty compressor like above, but a bit smaller.
If you have a harbor freight in your area, I can mail you the coupon if interested. It's good until 3/13/2010
