MOTEC ECU + stock ABS
Old 02-22-2010, 02:50 PM
Austrian Vette
Support Corvetteforum!
Austrian Vette's Avatar
Default MOTEC ECU + stock ABS
If I go MOTEC ECU and deinstall the stock ECU and BCM to do so, will I have a chance to keep the ABS working?
What yould I need to take care of ?
I hope anyone can help me on that.
Old 02-22-2010, 03:09 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Motec?
I've dealt with some Motec stuff, it ain't cheap that for sure!
depending on the model, you can get whatever you want including ABS.
You may need to keep the stock ECU piggy backed in if you want to keep the stock dash running though.
Old 02-22-2010, 03:21 PM
Austrian Vette
Originally Posted by BrianCunningham
Motec?
Yes, Motec is no way cheap, but it´s the best when it comes to ECU´s.
I will not use the stock dash anymore........I´ll install a digial dash, connected to the MOTEC ECU.
I just need to know if the ABS still works with the stock ECU and BCM removed, as the ABS ECU connects to the BCM or ECU, as far as I remember.
Old 02-22-2010, 03:32 PM
davidfarmer
davidfarmer's Avatar
I don't think so. You will likely need an aftermarket ABS system, or as Brian suggests, Keep the OEM ECM/BCM in a passive mode.
Old 02-22-2010, 03:35 PM
Austrian Vette
Thought so..........thanks !
Old 02-22-2010, 04:32 PM
BrianCunningham
FYI
http://www.motec.com.au/forum/
Old 02-22-2010, 08:50 PM
gkmccready
gkmccready's Avatar
What's the Motec offering that the stock ECU isn't? I've heard nothing but good about the stock ECUs and their programability... coming from a camp that loves Motec, Autronic, etc.
Old 02-22-2010, 10:03 PM
0Louis @ LG Motorsports
Former Vendor
Louis @ LG Motorsports's Avatar
Motec > Stock ECU
Old 02-23-2010, 12:02 AM
Austrian Vette
Cannot use digital dash on stock ECU.
Cannot use ignition cut on sequential gearbox on stock ECU.
More tables on the Motec to tune a ITB setup better.
Lot´s of things for a racecar, that the stock ECU just cannot do...
Old 02-23-2010, 01:27 AM
Former Vendor
If you can run ABS, and money isnt an issue, run the bosch race ABS. It needs inputs, but nothing like the stock ABS. As you begin to neuter the control modules from the stock system, things become unhappy.
You will need the Active 09+ sensors for that system.
Old 02-23-2010, 11:41 AM
gkmccready
gkmccready's Avatar
Yup. I guess a better question may have been: how extensive is your build that you require a Motec? :-)
Thanks! I know the Motec can sing & dance but was just curious what was taking you there.
Old 02-23-2010, 12:59 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
What kind of money are we talking for a Motec ECU compatible with a C5??
Old 02-23-2010, 01:43 PM
Former Vendor
I doubt they offer a plug and play ECU like the EVOs and Supras. If that WAS the case, it would be 4500-5500.
The biggest part, is making looms and getting everything to work right.
Custom Motec setup would run 12-25K, or more. It all depends on how radical you want to go.
Old 02-23-2010, 01:46 PM
Austrian Vette
Well, 700+hp 7 Liter engine with ITB setup, sequential transmission,
lightweight Racecar...........for now.
Full carbon body next season.
Extensive enough for me, to run a quality ECU.
Old 02-23-2010, 01:50 PM
Austrian Vette
Do you have a link for me, so I can look at such a setup.
Money is always an issue, but I try to not shortcut on anything.
I don´t have an idea what such a setup would cost...
Thanks.
Old 02-23-2010, 09:38 PM
jhester
jhester's Avatar
Thanks.
Louis @ LG Motorsports has talked to me in the past regarding the Bosch Motorsports setup.
Here is a link to the Bosch Motorsports - ABS M4 Kit
List price is 5890 euro; or $7995 USD (for the cheap kit with the OEM connectors; autosport option increases the price further)
While that sounds like alot, it is a full-motorsports ABS system with a 12-position adjustable switch to dial in system severity based on longitudinal tire grip, aero loading, and track surface.
If you want the best commercially available ABS system; that is it.
Old 02-24-2010, 10:40 AM
Austrian Vette
Thanks a lot for that Link !!!
To MOTEC ECU + stock ABS
Quick Reply: MOTEC ECU + stock ABS
