Tool used to push pins out on top of BBK Calipers
Old 02-22-2010, 03:26 PM
drivinfast
drivinfast's Avatar
Default Tool used to push pins out on top of BBK Calipers
pins on top of caliper that hold the pads in place.
I did a search, but am not finding the tool used to push these pins out with to swap the pads
Old 02-22-2010, 03:30 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I've not used those, but Stoptechs are actually long bolts that thread in. I'd make sure there isn't a bolt head hidden down inside, and if not, contact AP or the seller. If you have to press them out, that sounds like a pain in a rush (almost C6Z06 bad)
Old 02-22-2010, 03:43 PM
DarkMastyr
DarkMastyr's Avatar
Brembo uses the same system. You just tap them out.
Old 02-22-2010, 04:26 PM
mousecatcher
mousecatcher's Avatar
it's called a punch. probably 1/8"
Old 02-22-2010, 05:18 PM
Don Keefhardt
Don Keefhardt's Avatar
Get yourself a set of drifts / pin punches....you'll use them all the time.
http://www.harborfreight.com/cpi/cta...emnumber=93460
Old 02-22-2010, 06:04 PM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
The CTS-V Brembo's us the same system and I just use a punch, then tap them back into place when finished. I actually like them better than the StopTech / Wilwood calipers with bolts.
Old 02-22-2010, 06:28 PM
mousecatcher
I wouldn't know about Wilwood, but they are bolts on the StopTech's because they are 2 piece calipers and they bolt in the bridge plate for extra rigidity.
Either system is just as easy to maintain, IMHO.
If rigidity increases brake feel then the price/performance for the stoptechs is perhaps unbeatable.
Old 02-22-2010, 09:50 PM
drivinfast
drivinfast's Avatar
Thanks everyone. ill get a set i go to harbor freight about once a month. i called AP wants $8 for the tool, so with shipping ill just get a complete set.
To Tool used to push pins out on top of BBK Calipers
Quick Reply: Tool used to push pins out on top of BBK Calipers
