bedding PFC 99's
bedding PFC 99's
So picked up a set of these from MBS (on sale in another thread), will use them at NJMP in March. To bed new race pads, do you guys bed them on an empty section of street first, then swap them on at the track, or just put them on fresh at the track and use the first few laps?
Mine is a dedicated trak car, not street legal. I use the first session of Saturday to bed brakes. I am cold, track is relatively cold, and I just take an easy session. Always grid last out of consideration for others and go fast enough to stay out of their way and not let them catch you if you can. Otherwise, just point a lot.
I bed them on the street during a drive through an area with traffic lights at a time when there is light traffic. I drove around a few days on the street with them installed.
Be sure your rotors are not brand new--these should be used w/street pads for at least several weeks of daily street driving.
Received 1,749 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
swapped these pads on last night and went out late night to do a few snubs. boy, lots of dust. they don't seem to be releasing too well when I let off the brake pedal. I have a good firm pedal. any pointers or you think that's expected until they are broken in a bit more? I wouldn't say they are fully bedded yet.
How many times did you "snub" them? Seems like my XP12s suggested 4-6 60-25 mph stops and then 2-3 90-40 mph stops, park it and let it cool for 12hrs(?).
probably a total of 10 from progressively higher speeds and pedal pressure as per MBSbrakes instructions. I was on the street however so did not get over 70mph. That may have to wait until first couple of laps on the 29th.
If you do it on the street, just be careful! Try to find a place with long range visibility, no traffic, and as few potential obstacles entering the roadway as possible. You may find that it's impossible to get a really good bed-in on the street, simply because you can't get the pads hot enough. Race friction requires more heat to start transferring to the rotors. More heat is generated through stops from higher speeds (higher energy stops...where more rotating (kinetic) energy is transferred to heat energy).
This may be helpful for you...something I put together over the winter...explains a lot of the theory behind this topic:
http://www.essexparts.com/learning-center/Bed-in
