WARNING check your lug nut springs :)
Old 02-23-2010, 12:06 PM
froggy47
froggy47's Avatar
Default WARNING check your lug nut springs :)
I have had several of these wear out recently. They are oem bought from my Chevy dealer about 3 years ago near as I can tell.
They fail when I go to torque them down. Torque wrench just keeps turning.
Studs appear fine, I can put a new lug nut on and torque it down on the same stud.
Studs are stock.
Of course this is not a spring stuck into a lug nut, it's the thread in the lug nut peeling away or stripping out.
Anyone got a link to a decent lug nut vendor, not interested in color/anodized/engraved yadayada. Just something open & strong and FULLY THREADED so I can get a little more engagement.
I change wheels several times a month so they get heavy use.
Thanks.
Old 02-23-2010, 12:15 PM
RAFTRACER
RAFTRACER's Avatar
What torque setting are you using and do you ever lubricate the threads ????
Old 02-23-2010, 12:41 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
excellent question......never had that happen
Old 02-23-2010, 12:50 PM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I have been using the ones from Autozone for years with no issues.
Old 02-23-2010, 01:05 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
WTF???
Old 02-23-2010, 01:11 PM
Aardwolf
Aardwolf's Avatar
Is that a chinese re-manufactured lug nut?
Old 02-23-2010, 01:16 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
For my 92 I hit my local NAPA up every few years for 20 lug nuts so I've never seen this.
Old 02-23-2010, 01:27 PM
Shrek
Shrek's Avatar
Hey guys, check with your local tire shops. Our local Chevy dealer had a tire machine in the detail shop and did tons of custom wheel swaps. He had a 55 gallon drum cut in half and it was over flowing with lug nuts removed from brand new cars/trucks. He would let me dig through and take zip lock bags full of new nuts and I would drop off a six pack in return.
Old 02-23-2010, 04:32 PM
froggy47
froggy47's Avatar
I use 95#, the wrench is good, I lube the part where the nut surface contacts the rim surface. If I don't I get galling.
Old 02-23-2010, 04:33 PM
froggy47
froggy47's Avatar
Only if the GM dealer gets them there.
Old 02-23-2010, 04:54 PM
davidfarmer
you need to use anti-seize on the threads.
Old 02-23-2010, 04:57 PM
RAFTRACER
RAFTRACER's Avatar
Studs are stock.
Thanks.
Old 02-23-2010, 06:10 PM
Pumba
Pumba's Avatar
LocTite makes a Silver Grade Anti-Seize Stick - PN 37230 - that works very well for wheel stud threads. It's about $5.00 a tube.
You should also NEVER use an air or electric impact gun or a 12-point socket on lug nuts.
Old 02-23-2010, 06:43 PM
TedDBere
TedDBere's Avatar
Originally Posted by Pumba
You should also NEVER use an air or electric impact gun ... on lug nuts.
Old 02-23-2010, 06:58 PM
Pumba
Pumba's Avatar
"You should also NEVER use an air or electric impact gun or a 12-point socket on lug nuts."
The use of air or electric impact guns is never allowed in an automotive assembly plant for the installation of lug nuts. Such devices round the edges of the lug nuts and are impossible to regulate so that their torque does not overstress the wheel studs.
Take the extra time and break your lug nuts loose with a long rachet or breaker bar. After they are loose, you can safely use a battery powered drill to spin the lug nuts off the studs.
The same goes for the installation of lug nuts. You can use a battery powered drill to spin the lug nuts down, but a torque wrench, with a 6-point quality socket should be used to apply torque.
Ideally, torque should be applied in three stages - 50 lb-ft - 75 lb-ft - 95 or 100 lb-ft.
The lug nuts should be torqued in a star pattern - Start with nut #1 - cross over to a nut across the wheel from nut #1 - cross back to the nut that is next to nut #1, but is not next to nut #2.
Tighten the other two nuts following the first three. Do this for all three stages of torquing.
Old 02-23-2010, 07:01 PM
froggy47
froggy47's Avatar
Every tire store in the world uses impact tools and (correct me if I am wrong) every manufacturer upon original installation uses them (correction spindle nut runners - my bad), probably 5 nuts at a time.
Of course, not for the torque spec when the tire store or racer is finishing off.
Old 02-23-2010, 07:06 PM
froggy47
froggy47's Avatar
I OCCASIONALLY use some, maybe I should use it every time, but I thought the GM torque specs were for dry threads? Would you back off the torque spec if you use it every time?
To WARNING check your lug nut springs :)
Old 02-23-2010, 07:08 PM
Pumba
Pumba's Avatar
Every tire store in the world uses impact tools and (correct me if I am wrong) every manufacturer upon original installation uses them, probably 5 nuts at a time.
Of course, not for the torque spec.
Not true!
I am in the OEM automotive engineering business, and to my knowledge NONE of the automotive assembly plants use impact guns.
All that I have seen in use a 5 - 6 - 7 - 8 spindle nut runners. These are very expensive electric torque wrenches.
Most TIRE STORE gauge their employees worth by how much money can they bring into the store. The more tires that they dismount, change, and remount in a day the more they like the guy.
Very few of them are knowledgeable or care about what is best for your vehicle. It is only in recent years that TIRE STORES have started to use torque wrenches to tighten the lug nuts when they reinstall your wheels.
And, most of them improperly use the torque wrench!
Old 02-23-2010, 07:09 PM
Pumba
Pumba's Avatar
If you use the LocTite Silver Grade Anti Seize you do not need to reduce your torque.
Old 02-23-2010, 07:11 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
This is the reason why I tell people to throw away lug nuts often.
Randy
Quick Reply: WARNING check your lug nut springs :)
