My dyno numbers today...
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes
Dynojet w/SAE corrected: '03 Z06
AFR 205's/61cc
LG motorsports G5X3 cam
Fast injectors, Honker intake, OEM TB Katech ported, Melrose headers, no cats, OEM titanium Cat/back
With air-fuel readings of 13.0 up to 7K RPM cutoff
393.25 Torque/ 440.57 HP
Typical??
AFR 205's/61cc
Typical??
Oh and 440 rwhp with a cam/heads sounds great!
Thanks for the replies. Actually, with previous configuration (no AFR heads and LG cam) I got 387HP and 373T (everything else listed).
I got to tell you, that first 50HP was a heck of a lot cheaper than the last 50HP!!!!!!
100 octane, no cats/mufflers, stock airbridge w/K&N, stock T/B, stock exhaust manifolds..........389hp 381tq
And now they gave me longtubes to hang on there. Expecting another 12-15 hp if we are lucky.
OK, that makes sense . I was thinking the 100 octane might be a big part of it. You guys should do well with 400 rwhp and only 3180 lbs!
My 01Z has similiar mods, but without the AFR's, injectors and it got 425rwhp, so that is pretty good.
Location: If you don't weigh in you don't wrestle Road America
If you have EFI Live I can send you a tune and you can look it over. Our car made 385/378 with a 2 year old LS6.
Not to hijack the thread but here is the dyno graph of our T1 car, 2 year old LS6. This is 100 octane, stock air cleaner, paper filter, stock manifolds, no cats or mufflers pretty much 3" all the way back.
I was pretty suprised too, considering on your typical street car you need long tubes and a cold air intake to get these kind of numbers.
We'll have to see what long tubes does to the numbers.
By the way those are some great numbers with the head and cam especially the torque numbers. The hp numbers are on par with a stock C6Z.
NICE! Can't wait to see/hear the beast..
Man hate to say but for that big cam and kick **** heads with compression and other bolt on's ....only 440 Rwhp and what happend to torque ? seems lik you got only 10-20 Rwhp with just addition of 2k bucks heads. As with cam only G5x3 a Z06 got 425 Rwhp and more ......but 440 Rwhp is nice though. Whats power/torque at 3k rpm?
To answer your question of 3K RPM - 305T/175HP, at 4K RPM - 370T/285HP, at 5K RPM - 393T/375HP, at 6K RPM - 380T/430HP, last good reading was at 6.5K RPM 355T/440HP. Torque started dropping below 350 at around 6.7K but HP continued flat line at 440.
Of course I run an L98, but I am not sued to seeing HP higher than Torque.
So when are we going to go play?
As soon as I can build up the kitty again...... ouch! my billfold needs an excedrin.
VIR w/10/10ths 3/15/10
Putnam 4/03/10
so far, that's it. Of course, I know you and crew will probably hit everything this side of the Mississippi EXCEPT Putnam.
Putnam 4/03/10
