C5 hub/bearing T-55 Bolts
Old 02-27-2010, 03:59 PM
R Mackow
R Mackow's Avatar
Default C5 hub/bearing T-55 Bolts
I've taken the LF hub/bearing assembly off at least 3x now. How long do you keep reusing the same T-55 bolts? The "spline" on my T-55 "bit" is starting to deform.
Old 02-27-2010, 04:22 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
gary @ hardbar has some replacement bolts, I just ordered some recently
http://hardbarusa.com/hardbar/produc...roducts_id=115
Old 02-27-2010, 04:39 PM
CHJ In Virginia
CHJ In Virginia's Avatar
It is time to replace the bolts and your tool. Each time the bolt is torqued, it slightly deformes the threads and puts a lot of stress on them. Bolts are cheap, damage from a hub that comes loose at speed is not.
Old 02-27-2010, 06:10 PM
rasrboy
rasrboy's Avatar
Get rid of that Torx junk, Gary's 12 point socket head set up is way better not to mention the high grade strenght.
To C5 hub/bearing T-55 Bolts
Quick Reply: C5 hub/bearing T-55 Bolts
